-   -   long nose fender hardware question (http://forums.pelicanparts.com/porsche-911-technical-forum/415656-long-nose-fender-hardware-question.html)
CHILI 06-19-2008 10:37 PM
I wanted to put the bolts in the flange holes (the flange that holds the fender to the tub) to keep POR15 out of the threads but noticed that I can only thread them in about 4 turns.
Do the female threads taper? In other words, do they get tighter? I'm almost certain I'm using the original bolts.
TIA,
Chad
javadog 06-20-2008 05:06 AM
No.
JR
DW SD 06-20-2008 07:12 AM
chili
can you clean the holes? I didn't taper either.
Doug
CHILI 06-20-2008 04:53 PM
Hmm, ok. I guess the bolts I was using were cross threading because they are a different pitch.
I have a new fender hardware kit somewhere. I'll use them.
THanks guys!
