biergoat's Avatar
SSI Upgrade?
I have a '77 with a '75 engine, the thermal reactors have been replaced with "w"headers. I am wondering if there is an advantage in replacing the existing setup with new SSI or Dansk heat exchangers. Will an upgrade give more HP or help the engine run cooler? I believe the engine has over 120,000 miles on it, it will run up to 240 degrees on hot days (over 90f). OK, before you think I am crazy for even considering, the car runs strong and has great compression and leakdown results, 175-190 and 2% across the board respectively, what do you think?
1977 Minerva Blue 911S Targa
2017 Subaru Outback
2020 Toyota 4runner TRD Sport
Old 06-22-2008, 10:51 PM
the present exhaust with "tubes" is very restrictive. SSI will make a difference.
also get a front fender oil cooler.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-23-2008, 03:55 AM
it will definatly help with cooling and get you some decent heat in the fall and spring. the hp gain will be lower on a 2.7 maybe 10 hp but no more then that.. best of luck
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 06-23-2008, 05:23 AM
