Got problem need a quick answer
Hi, I want to fit a pair off SSI Heat exchangers and found a pair with oil-lines with only 30 minutes on them for a good price.
In the description it says will fit 3.2. I have a 1985 3.2 911. I have already found out from mailing the guy they dont have O2 Sensor socket. His response, weld one on. My question will these fit my 1985? Part No. SSI 143 4182, SSI 148 4940. I need to know ASAP. |
THE IRONMAN
Quick...Yes. With the welded bong.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Friend of Warren
Yes they will fit. You can get the bung at most auto parts stores. Need to drill a hole and get it welded on, but that is not a big deal.
I see you are in Amsterdam. I thought the ROW 3.2 engines didn't use the O2 sensor, but I could be wrong.
Kurt V No more Porsches, but a revolving number of motorcycles. |
just to let you know, that Euro 911s do have an O2 Sensor. Checked with Porsche Amsterdam. Nice guys.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
You can weld on the bong or get a SW chip that dose not require an O2.
I understand the differences between the early SSI which, have a thinner Flange and none protruding Header tube and later from 1984-89 have a thicker flange and protruding tube. Apart from that I understand they are the same. The early will fit the later but later will need modification-Phew!!! I need a beer
Slumlord
Lots of guys unplug the O2 sensor. You might not even need it.
Slumlord
THE IRONMAN
Bung...Bung...Bung...
heat duct mods required.
After speaking to Porsche Amsterdam and the UK, who said after I had given my chassis number that I did have a O2 Sensor. I then finally looking underneath my car-their is no O2 Sensor. So, Javadog you are Right!
Just to be sure, make sure you have a 930/20 engine. The engine number will be stamped in the right hand side of the case, to the right and towards the bottom of the cooling fan. It's a little hard to find, so grab a flashlight and start looking. If you have a 930/20, there was never an O2 sensor. If it is another engine type, you may have had a sensor and a previous owner may have removed it.
Only one way to know for sure. JR |
