db9146's Avatar
Help with Keys
Hope someone here can answer a question for me. On a 1982 911 SC I have for parts, the PO misplaced the key. I'd like to be able to pull one of the other lock cylinders and have a locksmith cut a key for it. The question is, can I use the glovebox lock cylinder to enable a locksmith to cut a key that willl work in the ignition? Seems this is the easiest cylinder to remove.
Other ideas?
Thanks.
Old 06-23-2008, 07:19 PM
dlagerstrom's Avatar
I don't know about cutting keys from a cylinder, but I can say that if the parts are all original the key is the same for the doors, ignition, and glove box. One key does all. The car came with two keys, one red and one black. There is a slight difference in the blanks so that the red one does not work on the glove box as it is the valet key.
Hope this helps.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 06-23-2008, 09:11 PM
I can say from experience that the glove box lock cylinder is not the easiest to get back in. The tricky part is that darn spring. It takes me less than a half hour to get the door handle out, but it took me a few months and several tries to get the glovebox lock put back together.
Old 06-23-2008, 09:41 PM
MarKoBrow's Avatar
I believe the tumbler in the passenger door has the same tumblers as the ignition. Take the door handle to your lock shop and they should be able to make you a key.
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 06-24-2008, 03:39 AM
db9146's Avatar
Thanks for the responses!
Old 06-24-2008, 06:43 AM
