Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Front Wheel Bearing Replacement - How tight should the lock nut be?
I just recently went thru the work of replacing the wheel bearings on my 911 SC. I am curious how tight to tighten up the retaining nut. To much and I bind the bearings and too loose and wobbly problems.
So how do you know when its the right tightness?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 06-25-2008, 09:39 AM
Senior Member
Superman's Avatar
About finger-tight. Do not put much force on this nut at all. Tighten just until the play is gone. Conventional wisdom is to tighten it so that a washer between the nut and bearing can be slid back and forth using the tip of a screwdriver. No prying. the washer should be slidable with finger-pressure. With 911's there should be essentially no wheel play. When you are done, the wheel and tire should not have lateral play.
Mocha 1978 911SC. "Coco"
Old 06-25-2008, 09:51 AM
I concur with Superman. However, before getting to this point, I'd suggest overtightening slightly to align the various components, then back off before adjusting to specs.
Sherwood
Old 06-25-2008, 10:55 AM
Sherwood
I just got done doing that this evening. Set the bearings, back off, set proper torque, a holdover from my aircraft maintenance days. Does it help, who knows.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 06-25-2008, 02:40 PM
Autodidactic user
David E. Clark's Avatar
The factory shop manual says 10 ft lbs, Bentley says 11 ft. lbs.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 06-25-2008, 03:03 PM
This is the torque spec for the clamping-screw on the lock-nut. You don't want to try and torque the lock-nut to 11ft-lbs! That would be an... unfortunate preload.
Superman has it although you probably want to rotate the hub while you are tightening the lock-nut and checking that thrust washer. The procedure for setting preload in on 401-12 in the Bently manual if you want to see it for your self.
1989 Carrera 3.2L in 993 bodywork
Old 06-25-2008, 09:56 PM
Black and Blue
Kemo's Avatar
thanks for all the replies guys, ill be reinstalling the assembly onto the struts this weekend.
Kemo
Old 06-26-2008, 06:53 AM
