How to fIt HID headlights on my 84
I want to know what model of HID headlight I need to buy to fit on my 84, 911
and how install them...anyone do this job the headlight I like are this one HID ballast fit |
Member 911 Anonymous
It depends on what type of headlights you have now.
If H1 or H4, answer is a NO. If you have the "sugar scoop" then it is possible but kit has to be the same diameter and the ballast may need to go behind bucket in the wheel well. These kits require a clean/direct 12 volt source so I suggest a headlight relay kit, this will also save your very expensive switch at the steering wheel stalk. Good luck, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
