-   -   Wires for instruments. I'm an idiot. PLEASE help! (http://forums.pelicanparts.com/porsche-911-technical-forum/416742-wires-instruments-im-idiot-please-help.html)
watson 06-26-2008 03:47 PM
I REALLY need someones help right now.
I need to start my engine after my renovation, this weekend. Everything is perfect, except my small and large combination instrument.
I'm not sure how to connect the wires, because I forgot to mark them when I took them out (big idiot... I know).
I'm using three diagrams to be sure to do it right, but i'm still not sure...
Can you see theese pictures and tell me if i'm doing it right or wrong? :confused:
911T - 1971
http://rwi.dk/images/smallcom.jpg
http://rwi.dk/images/smallcom1.jpg
http://rwi.dk/images/largecom.jpg
http://rwi.dk/images/largecom1.jpg
http://rwi.dk/images/diagram.jpg
Thanks guys!
tcar 06-26-2008 03:50 PM
What car? Year?
Pics don't look like the green 71 t.
watson 06-26-2008 04:43 PM
Originally Posted by tcar (Post 4026259)
What car? Year?
It WAS a green '71.
Now it's light ivory '71.
:p
Jim727 06-26-2008 05:13 PM
From a Green(!) '71:
Small instrument-
Solid Green -> Fuel
Green/Grey -> Oil
Large instrument-
Green/Red -> Oil Pressure
Green/Black -> Oil Temp
Jim
watson 06-26-2008 11:57 PM
Small instrument-
Solid Green -> Fuel
Green/Grey -> Oil
Large instrument-
Jim
Thanks Jim, but I can see that from the diagram. I need to know wich connection points i have to use behind the instruments.
Jim727 06-27-2008 01:14 AM
OK - pulled my gauges out and....
For your large instrument, it compares with mine except for the top (12 o'clock) connections I have a black with white stripe and a brown with grey dot. Below that I have a single black with green stripe.
For the small instrument, starting at 12 o'clock I have a black with blue stripe with a double ground directly below it. To the right of that is the double red/black like yours. Next clockwise I have a solid green, again like yours. Next clockwise is the large fitting and I have a double male spade with a black wire plus the red/black jumpered to it. Immediately to its left I have an empty male spade connector where you show your black wire. Again clockwise the red/black followed by the green/grey like yours.
Sorry for the text description - tried to get photos but couldn't get the camera to make a decent closeup. Hopefully it helps.
Jim
Peterfrans 06-27-2008 06:06 AM
You made an error with the small combi instrument:
- the black wire should not be used a ground (only the brown)
- you used the instrument lighting bulb where the warning light for the fuel level should go. This light is connected to a red/black and the black wire
Ryce Stallings 06-27-2008 10:35 AM
Does the gauge fry if the wires are wrong, I might have a similar concern on one of my gauges from a 77 911. I haven't put power to it yet. I did make a diagram but one still seems iffy!
watson 06-27-2008 05:48 PM
Uh! Thanks man!
I will correct it tomorrow:)
