Send a message via MSN to watson
Wires for instruments. I'm an idiot. PLEASE help!
I REALLY need someones help right now.
I need to start my engine after my renovation, this weekend. Everything is perfect, except my small and large combination instrument.
I'm not sure how to connect the wires, because I forgot to mark them when I took them out (big idiot... I know).
I'm using three diagrams to be sure to do it right, but i'm still not sure...
Can you see theese pictures and tell me if i'm doing it right or wrong?
911T - 1971
Thanks guys!
Irish Green Porsche 911T 1971
Denmark (Scandinavia)...
Old 06-26-2008, 03:47 PM
What car? Year?
Pics don't look like the green 71 t.
Old 06-26-2008, 03:50 PM
Originally Posted by tcar View Post
What car? Year?
It WAS a green '71.
Now it's light ivory '71.
Old 06-26-2008, 04:43 PM
Tree-Hugging Member
Jim727's Avatar
From a Green(!) '71:
Small instrument-
Solid Green -> Fuel
Green/Grey -> Oil
Large instrument-
Green/Red -> Oil Pressure
Green/Black -> Oil Temp
Jim
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 06-26-2008, 05:13 PM
Small instrument-
Solid Green -> Fuel
Green/Grey -> Oil
Large instrument-
Jim
Thanks Jim, but I can see that from the diagram. I need to know wich connection points i have to use behind the instruments.
Old 06-26-2008, 11:57 PM
Tree-Hugging Member
Jim727's Avatar
OK - pulled my gauges out and....
For your large instrument, it compares with mine except for the top (12 o'clock) connections I have a black with white stripe and a brown with grey dot. Below that I have a single black with green stripe.
For the small instrument, starting at 12 o'clock I have a black with blue stripe with a double ground directly below it. To the right of that is the double red/black like yours. Next clockwise I have a solid green, again like yours. Next clockwise is the large fitting and I have a double male spade with a black wire plus the red/black jumpered to it. Immediately to its left I have an empty male spade connector where you show your black wire. Again clockwise the red/black followed by the green/grey like yours.
Sorry for the text description - tried to get photos but couldn't get the camera to make a decent closeup. Hopefully it helps.
Jim
Old 06-27-2008, 01:14 AM
You made an error with the small combi instrument:
- the black wire should not be used a ground (only the brown)
- you used the instrument lighting bulb where the warning light for the fuel level should go. This light is connected to a red/black and the black wire
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 06-27-2008, 06:06 AM
Does the gauge fry if the wires are wrong, I might have a similar concern on one of my gauges from a 77 911. I haven't put power to it yet. I did make a diagram but one still seems iffy!
Old 06-27-2008, 10:35 AM
Uh! Thanks man!
I will correct it tomorrow
Old 06-27-2008, 05:48 PM
