Sunroof tray 'glue' removal
Hello Pelicans.
Could someone please give me some options on how to remove the sunroof tray 'glue' ? It is some sort of body adhesive but I can't get it to budge. Pretty good for something that was applied in the '70's. Thank you.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
3M makes a pretty good adhesive remover. I have never tried it that application but it does work on most dried old glue & adhesive.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
a citrus oil based product called "goof off" worked for me.
wd40 might work . always test in a un conspicuous spot first
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
I may have been too ambiguous.
The tray is still attached to the underside of the roof. I have all the welds ground off and now the only thing holding it up there is the factory glue (epoxy?) I can't seem to separate the sunroof from the roof skin. All help is appreciated. Thank you. (Thank you GH85Carrera and Bob for your suggestions)
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. Last edited by 9elf; 09-22-2008 at 08:49 PM.. |
'Goof off' is the answer.
Thanks go to you Bob (robmog).
