SP2 SP2 is offline
SP2's Avatar
How much rust is tolerable - floorpan
Sorry guys, I don't have a photo, but on my 69 car there was some superficial rust that I sanded down to the good metal. But I can see very faint pock mark thingies that are very tiny. I don't want to get too perfectionist minded. My plan was to sand the whole floor pan to metal, por15 metal prep it, rinse it with water (that's what the bottle says to do), then por15 it with their semigloss formulation.
So where do you draw the line with rust? (after looking at his recent posts, I almost feel as if there is a little chris nielsen on my shoulder telling me to resect it.)
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 06-27-2008, 09:57 PM
3.2 CAB's Avatar
I really don't want ANY rust, but... it happens to even the very best of any steel bodied vehicle. The only thing you can do if find it and kill it! The amount of rust that you described seems to be a very minor amount and should be easily taken care of. It looks like you have a pretty solid plan of attack. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-28-2008, 03:25 PM
Tree-Hugging Member
Jim727's Avatar
Interesting - that along with some a/c wiring improvements was my project for last week. No rust is good rust, but since you are dealing with minor surface rust you are catching it before it becomes a cancer. I agree that your plan of attack is a good one and there is really no good reason to cut and weld. I used the KBS coatings instead of the POR, but they are pretty similar.
One thing I would add to your plan is to get into the battery boxes. "As long as you're in there" you'll have most of the stuff out of the trunk and the wire wheel in hand. Since the battery boxes take a lot of abuse they are likely to be as bad - or worse - than the pan area. I cleaned mine out and gave them three coats of the KBS and feel much better until I get to the "real" trunk cleanup (tank out, wiring out, soda blast the area, KBS the whole thing and reassemble) which I can now delay for five years or so. Looks great, too.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 06-28-2008, 05:19 PM
