-   -   Idenify the noise (http://forums.pelicanparts.com/porsche-911-technical-forum/417271-idenify-noise.html)
Won 06-29-2008 08:13 PM
Idenify the noise
You can hear it here:
http://members.shaw.ca/midnightluck/noise.mp3
At the time of recording: engine up to operating temperature, oil level and pressure normal, car sitting level. Same noise when engine is cold. Recently installed a used Carrera tensioners, disassembled and cleaned in ultrasonic bath which have been problem free. Tried with the fan belt disconnected but the noise is still there.
Unknown mileage/time since last valve adjustment - one coming up very soon. It's coming from the driver side bank of the engine, most likely from the valve area. What do you think it is?
Won 06-30-2008 10:07 PM
In case it wasn't clear, I'm talking about the metallic squeeling just as the engine stops turning.
haycait911 06-30-2008 11:58 PM
how about a pic of the engine. is the smog pump gone? doesn't sound internal to me.
rusnak 07-01-2008 12:08 AM
is there something stuck in the crankshaft pulley well? Whatever it is, it sounds dry.
Trog 07-01-2008 05:12 AM
Just a guess, but I would check the alternator bearing. Try again with fan belt disconnected.
Por_sha911 07-01-2008 08:03 AM
But don't run it for long without the belt.
Won 07-01-2008 10:32 AM
As I mentioned the noise persists without the fan belt. I thought it might even be a squeeky belt but that's not it either. No foreign object in the pulley area. A/C compressor gone, never had an air pump.
