Porsche Crest 911 Carrera 85 does not start and more...
It is time to take my '85 out of summer storage (this is Florida - I put it up on summer and drive it in fall/winter/spring -- the A/C is less than adequate for this weather.) I always try to crank it and go for a small spin every so often. That said the last time was approx 1 mont ago.
Yesterday, when I was going to take it out, it just did not start at all. It cranked strong, but not a single puff, cough, smoke, nothing.
...and more... The battery gets consistently dead after about a week of inactivity, I charge it overnight,and it goes back to work strong, so I believe the batt is okay, however, I think it should stay alive longer than that. Today I try to crank it again and the battery is dead. Putting 2 'n 2 together, could I have a short on the ignition circuit?
Please help!!!
Where do I start?
Old 10-20-2007, 09:20 AM
When storing I use a Battery post cutoff switch and a Battery Tender.
Your DME relay may have gone out. If you do a search you will find info on removing and resoldering the cold/cracked joints on the relay's circuit board. This will help in many cases. BTW, it is located right under the front of the driver's seat.
Carrera owners are best off carrying a DME relay around.
Add: Here's a recent thread on relay repair: 87 Carrera DME failure?
Also, welcome to the board!
Warren & Ron, may you rest in Peace.
Old 10-20-2007, 09:39 AM
williecoyote's Avatar
Did you check if there is fuel at the motor?
Will
85 carrera
Old 10-20-2007, 10:06 AM
As a matter of fact I did. The gas gauge showed I had +/- 1/4 tank, but I still went to the gas station bought 5gal just in case the gauge was messed up.
Good point though.
Thanks Will!
Old 10-20-2007, 03:53 PM
Thanks Rick! (For the welcome and for the advice.)
I started to disconnect the battery after I found out how quickly it gets drained. By the way, is a week or two time enough for a battery to die? Or should I start looking for some electric issues?
Old 10-20-2007, 03:56 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Your Carerra is like mine, left alone for a week, it will drain the battery ( an Optima). I leave mine on a battery minder to keep it topped off when not in use. As to your no start, It could be several things, mine turned out to be the DME (Motronic). The transistor for the final stage driver for the coil died.. There is a guy here in South Florida that repairs Motronics for $250 and will do a bench test for $50-$75. Does good work. Very happy, 24 hour turn around on mine, but he was an 45 min. drive for me. If you are here in So. Fla. let me know, we can find out real quick if it is your DME. I am in WPB.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 10-20-2007, 05:38 PM
Wash. State
nesslar's Avatar
Please swap out the DME relay and keep a spare. Try this first, and no matter what, as you need a spare anyway even if the origignal is still good. There's a good chance you can fix your no-start problem in this way for $30.
Old 10-20-2007, 06:10 PM
Check to see if your fuel pump is working.
Will
85 carrera
Old 10-21-2007, 08:07 AM
Thanks 'DonMo'! I ended up reading the article on how to fix the DME realy and gave it a try. It worked!!! Now I am ordering a new one, I will keep the repaired one as a spare.
I will definitely keep in mind your offer for the motronic. I would not mind to drive to WPB from Green Cove Springs, if I can save myself a thousand bucks.
Thanks again!
Enrique.
Old 10-22-2007, 07:10 PM
That is kind'a what I did. Really I followed the article about repairing the DME relay (resoldering the connections). I worked like a champ. I am ordering he new one as we speak.
Thanks nesslar!
Old 10-22-2007, 07:12 PM
DonMo; What is the contact info on your repair source? Thanks.....
Mike Pate
baby sitting '88 911 Commemorative Edition (60k miles) for son in Baghdad
Old 07-01-2008, 08:29 AM
DonMo's Avatar
Specialized ECU at 3059890724
I don't know what his prices are now but if you mention that a guy from West Palm Beach who had his motronic repaired by him, he may remember.
I payed $250 about a year ago.
DonMo
Columbia, SC
"Go Hokies"
Old 07-01-2008, 03:31 PM
Greetings,
Enrigue mentioned repairing the DME relay, I didn't know you could do that. I always carry a spare DME, but it would be nice to repair the broken one (when indeed it goes). Can someone point me in the direction on how to fix it?
Thanks.
Scott
___________________________
1985 Carrera Targa - Guards Red
2006 Acura TSX Navigation - Milano Red
Old 07-01-2008, 06:30 PM
DonMo's Avatar
Cold solder joints plagued the relay as well as the DME(Motronic). A good eye aided by a magnifying glass should ID the cracked solder, flow new solder on it and that should work. If it is beyond cold solder joints, I would buy a new one.
DonMo
Columbia, SC
"Go Hokies"
Old 07-02-2008, 03:01 AM
Thanks very much. Even somewhat more than $250.00 beast $1400.00
Mike Pate
Old 07-02-2008, 05:32 AM
