4flyboy's Avatar
How do I add a seat belt anchor to an '85?
I bought a pair of used non-electric blue sport seats for my '85 Carrera and they don't include the side seat mounts that my old seats had.
Is there a hole in my floor from earlier SC models that will make this mod simple?
I don't want to screw around in this area and for obvious reasons I want to do this right.
Thanks,
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-02-2008, 10:36 AM
Crusty Conservative
silverc4s's Avatar
The folks at PEP engineering used to sell the bracket, bolt & the self locking flat nut assy. I used it, it is a PITA to install, but once in is worry free...
Check with them. I think it is www.peparts.com
This is niche market supplier, not a Pelican competitor.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 07-02-2008, 01:00 PM
You might try the separate-piece 964 seat bracket...as described by KTL here--->
Consensus on "Best" Way to Mount Sparco Race Seat
It mimics the welded-in bracket that is on your 85 seat/slider right now. The 964 piece bolts-in instead, and you may need add'l washers at the other 3 corners of your chair to compensate.... but it's doable.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-02-2008, 01:16 PM
4flyboy's Avatar
Thanks Wil......
S.
Scott
Old 07-02-2008, 01:46 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Wil is always a great source of information. I'll add to his recommendation. The 964 RS and/or 928 seat bracket like the one pictured in the link would be great- IF YOU COULD GET IT! I ordered this from Pelican in March and haven't heard diddly squat about it on backorder from Germany.
So the next best alternative in my opinion is to go with the very nice stainless (and therefore a bit spendy) Brey Krause side seatbelt mount adapter. It's part number R-9005 and retails for about $70
See the additional spacer they provide? You simply use this on the other side at the rear and it adds only a slight rear rise to the seat. The plate is very thin since it's high strength stainless.
Kevin L
'86 Carrera "Larry"
Old 07-02-2008, 03:30 PM
4flyboy, I dig your signature quote, having been there in suddenly single-engine twins. Dick Collins, right? He and I (and my now-wife) used to work together at Flying.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-02-2008, 03:40 PM
