250 bhp from CIS ?
Hi all, is it beyond the bounds of possibility to get 250 bhp from my 82 SC 3.0 using CIS? I have heard the an SSI exhaust and 964 cams will give "up to 50 bhp improvement". It is in normal N.American trim at the moment.
Too many cars, not enough moolah... |
"O"man(are we in trouble)
I have done it and I believe the realistic figure is more like 20+, at the most 30 HP. It's still a nice boost for an SC in lightweight trim.
Senior Member
Not a chance.
But I do strongly recommend the improvements you mentioned. They will improve performance. I'm not even sure the cams will raise horsepower, but they will make your car more fun to drive. More torque under 4000 rpm. A 30-hp gain is unlikely. Like Widgeon said, perhaps around 20. But again, those two improvements will make a difference you will notice and appreciate. The engine just "likes" the SSI's better than the stock heat exchangers.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
AutoBahned
sure you can -- with a turbo...
Trotskyite
Hell you could get 500... for a few glorious seconds.
Grip Fast |
Just for fun, if one were to ditch the CIS for carbs, would the Hp jump that dramatically in the nearly stock configuration decribed above?
Nitrous anyone?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
AutoBahned
No, but the fun would jump significantly if not dramatically
Evil Genius
See my sig. Superman is right, more fun and pulls hard from 4-6K with web 20/21 cams and SSIs, but nope, nowhere near even breaking 200 h.p on a dyno. 180-185 dyno h.p max on a good day.
Facts and data over-rule rumours and opinions anyday.
Life is a big ocean to swim in. Wag more, bark less.
The '82 3.0 is a "small port" motor, and is limited as far as the peak power it will achieve with these changes. I've seen a fresh '83 with 20/21's, SSI's, and a Monty muffler pull 173 rwhp or so on the dyno. My son's '79 SC with SSI's, a Dansk single out sport muffler, and stock cams ran 180 rwhp on the same dyno. The difference between the early large port 3.0 and the later small port 3.0.
The biggest power improvement on the 3.0 (of either port size) is to simply get rid of the CIS and replace it with carburetors. Add that to the mix, and you can count on another 10-15 hp on top of the 10-15 you will get with the cams and exhaust. The whole package - cams, exhaust, and carbs - might be worth 30 hp over stock. A very noticeable improvement at that. You will, however, lose significant gas milage over the CIS. That might get increasingly important.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
3.0 w/CIS.....................
Has anyone tried a Nitrous setup on a 3.0 w/CIS? That should make some interesting numbers!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
What does a ROW SC or Carrera 3.0 engine typically dyno vs a US spec one? Just curious.
Also, how does a 3.0 with 964 cams/SSIs compare to a chipped 3.2 with SSIs? Sorry, just curious. I'm sure these are all #s 50%+ higher than what my car would make...
Sepia brown 1971 911T. |
I think those are really good questions and along the line of what I was asking.....
![]() Dyno plot before rebuild, stock apart from SSIs: ![]() Lost some mid-range torque, peak power now higher up the rev range (due to not increasing the cr I suspect). Much more top end power.
'82 911 SC - Slightly modified (not nearly light enough, 1130kg on 1/4 tank !) - 964 cams 232.1 bhp Last edited by Gary.H; 07-03-2008 at 01:06 AM.. |
Yes, but far from worth it.
230hp 3.0 with CIS is almost in "not worth it" class. Price/performance starts increasing exponentially after 230... Arguably, you could fit 930 CIS and get it to breathe more freely, then use very radical cams but intake pulses would kill the idle and low rev driveability.
Thank you for your time, |
Not worth it............
In a way I agree with Goran. Unless.....you are going to have to do a top end job anyway. Now all you are out is the extra cost of the cams which makes the work more justifiable. Also, I know first hand the effect of adding SSI exhausts to a 3.0 engine. That one change made my SC sooooooo much more fun to drive! Of course it would be nice if one had the $$$ to go ahead and increase the compression and maybe move up to 3.2 liters, etc. But, sometimes the fun is in taking small steps and savoring the results.
Original Owner
Need I say more?
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
coolcavaracing.com
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
grateful user
yes, more details on the nitrous k.
