Slippery Slope Victim
Preliminary dyno numbers on the Beast
Got some preliminary dyno numbers today.
The 3.8 Beast put down 360 HP at the wheels on the dyno. More tuning has to be done both on the dyno and on the road. I did'nt get the torque numbers. Figuring 15% loss..........that's approximatley 414 HP at the flywheel. ![]() We'll be doing an official dyno run next week. We were shooting for 425hp ![]() More to come.
Mike² 1985 M491 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Congrats!
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Navin Johnson
Mike,
I'm thinking I'm going to need alot of left seat time in that car when we are at the track... My own car is only 200 hp
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Yikes !!! thats a lot of power
Put on a happy face guy... you've got a turbo motor with zero lag that revs to 8000+
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
I am gonna feel silly when I post the graphs of my 3.4.............
![]() Cheers
![]() Cheers
Thanks fellas,
Bill still feels he can extract a little more power. He's upset that we did'nt go with higher compression. Tim.......you know you can take her anytime around any track. Now the problem is going to be putting the power down to the ground. I've got a feva and the only cure for it is more rubber! Tach goes out to be converted to 10,000 rpm.
Mike² 1985 M491 Last edited by NY65912; 07-03-2008 at 03:30 AM.. |
wow, that's nice
very nice Last edited by jbrinkley; 07-03-2008 at 03:44 AM.. |
Damn! I wouldn't have thought an air-cooled NA engine could pull that.
What are the engine specs?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Specs are:
Based on a 3.2 case – boat tailed 3.2 74.4mm crank stroked to 76.4mm Re-nitrate Using 2” rod journals utilizing NASCAR type rod bearings. Center drill for better oiling to #2 and #5 rods (special center main bearing) engine will be able to turn to 8600 rpms, but we are holding it down to under 8000 rpms. Custom Pauter Connecting Rods – using Raceware Hardware Camgrinder -DC62 profile on a 108° lobe center Race Springs, Ti Retainers 3.2 Heads – Dual Plugged & Ported 102mm LN Nickies 11.3 to 1 CR JE Pistons coated 52mm ITB’s big injectors – FP Regulator (plus all kinds of other stuff) Smart Racing Oil Filter Console 1¾” Nabel’s Headers into an (M&K Sport Muffler for street) M&K Shorties on the track Spark and Fuel controlled by Haltech E-8 Engine Management System Crank Fired Wasted Spark Accel Coil Packs Light weight Al flywheel and HD clutch Muahhhhhh
Mike² 1985 M491 |
With that compression ratio, I take it this is a track only (i.e. race fuel only) car.
Holy cow Mike. That car is going to HONK!
Have a great July 4th weekend, I can't wait to see (and hear) this car in person.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I have wondered about the idea of a lower CR engine built to the same specs.
The displacement should provide the torque needed to move along nicely. I'll use race gas 101 minimum. Hey John, I can't wait for you to hear it in person as well. Bill took it out on the road for some testing. He said that in the 2k-3k rpm range it was not a happy engine. BUT......over 4500 rpms he said it was like someone lit a rocket. And, around 6300 rpms it came alive even more and pulled hard all the way up to the seemingly non existant redline. As mentioned before, the tach is going to be reworked to a 10K unit. I was most taken by the sound of this engine. Very hairy.
Mike² 1985 M491 |
MBruns for President
Wow!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
