Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Sport Muffler Conversion, RSR Style?
I'm toying with the idea of converting my early muffler to a dual-outlet sport muffler. However, I don't want the narrow twin tips...I prefer them wider, so they match up with the rear bumperette location, as they were on the RSR.
Questions:
1. Can I simply move the exit pipes further to the outside, or were they in their locations for a reason?
This is what I am thinking of doing:
2. I also have a flowmaster 2 in 2 out that was the original plan for the muffler. Is there any advantage to sticking with the original plan and just mounting it instead of going with the sport exhaust??
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-21-2008, 09:02 PM
RETIRED
Joe Bob's Avatar
Sure, why not?
2012 ML350 3.0 Turbo Diesel
Old 04-22-2008, 12:33 AM
It shouldn't make any difference. I put my pipes just to the inside edge of the bumperettes.
Richard Newton
Autocross Performance Handbook
Ultimate Garage Handbook
Old 04-22-2008, 03:00 AM
Carmagic.us
rothaus's Avatar
Check this out, this is an other way to convert to dual exhaust pipe
http://www.dietersmotorsports.com/twinpipe911.htm
Cheers
Engelbert
http://carmagic.us
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 04-22-2008, 04:14 AM
T77911S's Avatar
let us know how it goes. i have been considering this mod too
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-22-2008, 05:06 AM
Midwest R Gruppe
t6dpilot's Avatar
I considered this mod also before a really nice sport muffler (narrow pipe version) fell into my lap. I really like the look and sound of the triple outlet exhaust of Scyip Designs. It has a really great sound and I wonder what they did to the internals that is different from the factory muffler. Looking forward to your solution.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 04-22-2008, 06:57 AM
175K911's Avatar
Questions:
Something like this? This is Ben's 911R M&K muffler.
(BTW- I modified a dual in muffler like you want to do, and it's pretty loud. Basically the outlets are lined up with the inlets so there's nothing muffling the exhaust as it goes through the can.)
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 04-22-2008, 07:58 AM
Carmagic.us
rothaus's Avatar
This must be very loud !
It looks to me that the gasflow is as the arrows show below for the stock one.
The modified one is just straight through
I like the conversion with the second exhaust on the right side, like this page describeds
twinpipe911
Cheers
Engelbert
http://carmagic.us
Old 04-22-2008, 09:48 AM
AutoBahned
RWebb's Avatar
I would exercise some caution in purchasing or modifying a muffler.
Engine dyno testing has shown that most aftermarket mufflers actually REDUCED hp(!) Check out Bruce A's book and some of his columns for some of the details. Other data exist but are closely held.
As Dr. Brakeberg recently noted on another thread, reinventing the wheel is not always so smart.
One Tidbit:
On the 993, P AG spaced the rear exit tips at a precise distance apart based on wavelengths of the noise components to achieve reduced noise. That is in one of the more recent UpFookin' volumes - maybe the glossy covered one or the one before it.
Good Luck - and decide if you want performance, noise, or just Bling.
Old 04-22-2008, 10:49 AM
cnielsen's Avatar
Like this one?
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 04-29-2008, 10:35 PM
Rennch on YouTube
rennch's Avatar
Yea...that one looks really cool. Is it loud as hell? (Or was it loud as hell?)
Michael O'Neal -
Old 04-30-2008, 07:22 AM
Fleming's Avatar
Michael, if you start with a Dansk muffler they look somewhat different on the inside. But they can be mod'ed similar to what sculptor Mr. Jeff Gamble did (so many years ago).
Old 04-30-2008, 07:57 AM
Rennch on YouTube
rennch's Avatar
Looks cool, but it's not what I have. I actually have a flowmaster muffler I was going to use for this, so I might just go that route. But I was thinking of doing a sport mod just to see if I could.
Michael O'Neal -
Old 04-30-2008, 07:59 AM
I'd like to inquire the results of these modifications? The plans seem pretty defined. I wonder why that particular approach or was it just seat-of-the-pants engineering?
Is the inside of the 2in/2out Dansk different?
Sherwood
Old 04-30-2008, 10:07 AM
My best guess is you might concider:
Cutting off the stock exaust tip.
Then cut it away further on the inside and up to the first bulk head.
Then, install your two tips out side of the two outer bulk heads.
You will have come close to making it a muffler equal to just adding a second tip to the right side.
A muffler with a mirrored second tube added to the right side, is a proven design that makes Hp and is not concided to loud.
This is what I would do.
Old 04-30-2008, 10:32 AM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
How can you distinguish the difference b/n a stock muffler and others?
Old 04-30-2008, 01:26 PM
Note on the orange car above, the new tips are not direct accross form the in-side which would be like a a straight pipe.
They are on the out side of the outside bulk heads. You will be able to see where these bulk heads are located from the outside of the muffler.
With the mod as I noted above, if you wanted to you would be able to plug the right and have a near stock sound if needed. You might start with the right pipe only having a 1" hole in it and open it further if more sound it wanted.
Old 04-30-2008, 04:37 PM
curtisaa's Avatar
Muffler mods
I just tried this and it turns out to be cheaper to buy a new one, than doing the mods.
Old 04-30-2008, 06:14 PM
Rennch on YouTube
rennch's Avatar
I like it.
How is it cheaper to buy a new one? I can do this in an hour or two for like, 15 bucks.
Michael O'Neal -
Old 05-01-2008, 12:57 AM
I did the whole thing for less than $50. That was because I had to pay for the welding. If you can get a new 911 muffler for less than $50 please let us know.
Richard Newton
Old 05-01-2008, 03:30 AM
