My other ride is a C-130J
Is this an Air Box Hose?
Hello Gang,
In the process of resolving a spark plug issue I discovered this situation. There appears to be hose connection to the air box and I discovered a cut hose nearby the air box. The cut hose goes into the vehicle on the drivers side under and in front of the Fuel Filter. Does this hose go into the air box? Any Ideas? There are yellow screwdrivers indicating the hose and air box. Thanks RG Najarian
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
That hose is for the charcoal cannister, and not being connected will not affect running quality. A small amount of unfiltered air will enter the airbox at that hose connection so you should probably figure out an easy way to hook up the cannister hose, maybe its condition is good enough to put back on and hold with a clamp - if it's long enough to reach the airbox.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 07-18-2008 at 11:20 AM.. |
did you have cruise?
83 SC |
Yes I have cruise control
No it does not work I hope they are connected
It is possible that the hose is (was) from the cruise control servo and was just pushed into the opening in the metal support behind the engine.
Lorne M.
83 SC |
Upon closer inspection the hose does seem to be from the charcoal canister. Too bad it wasn't for the cruise control.
you can buy the brass adapter from our host for about 5 or 6 bucks , I did a couple of month ago
83 SC |
