82SC CIS Rebuild with questions about hoses in wrong locations
I have pulled the CIS from my 82SC USA spec because I'm having a problem with detonation. After many of hours looking for answers and testing many things one thing was for sure the old rubber was porous and cracked and could be heard with carb cleaner changing engine note. During this process I have found a number of issues I would like to discuss.
1. I think the breather hose is backward not to mention kinked and cracking. The short hose was attached from the oil tank to the coupler (with a kink) and the long hose went from the coupler to the breather on the engine (with a kink). From part numbers I see short hose on engine breather and long on oil tank but wanted to confirm.
2. The vacuum lines on the front of t-body looked to be correct with top (80% broken and fell apart during removal) going to WUR and the lower going to retard port on distributor.
3. Moving to the vacuum lines on the rear of t-body I think things are backward. The top went to the distributor advance and the lower was blocked off. I'm under the impression the top goes to the deceleration valve and the bottom to the distributor advance. So far this is what I have found that has not looked correct and wanted to clarify during disassembly. My plan is to replace all bad rubber as well as injector sleeves and o-rings.
I have been having fun with this so far during the first 4 months of ownership and can't wait to have it back together. First a partial drop to fix oil leak t-stat o-ring two weeks in and now CIS rebuild. I only wish I waited to do T-stat o-ring because now would have been the time LOL.
82 911SC
74 MGB
97 Land Rover Discovery
Old 07-21-2008, 03:28 PM
