3rd_gear_Ted's Avatar
Clunking @ slow roll on my 911SC
Newbie here, I sure could use some input on why my car has a clunking noise when it coasts real slow? BTW both axles are newly rebuilt.
Old 07-21-2008, 05:25 PM
Start with the bolts on the CV joints--could be the rebuilder did not torque them enough and they have worked loose.
If all bolts are tight, it may be the CV itself, even though it was rebuilt.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-21-2008, 05:43 PM
Less brakes, more gas!
euro911sc's Avatar
It could also be a loose rear sway bar. When they get loose they clunk when turning. Easy to tighten up!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-21-2008, 08:33 PM
Transmission differential noise
When I put my 911 SC on jack stands, take off the wheels, raise up the axles level and run the car for a little while in 1st gear. As the transmission is put in neutral and the axles coast down there is a clunking noise eminating from the differential. I put a long screwdriver to my ear and listened to the differential as the transmission went from being in gear to neutral and the sound is definitely coming from the differential. Does anybody have any input as to what is occurring BTW both axles are rebuilt with new parts.
Old 07-25-2008, 02:29 PM
RETIRED
Joe Bob's Avatar
A chunk could be missing in the ring and pinion....but you would hear it all gears and at different speeds when in different gears.
2012 ML350 3.0 Turbo Diesel
Old 07-25-2008, 03:25 PM
Clunking has always been CV's for me. I could eventually hear it while driving, most noticeable turning one way or the other but very difficult to pinpoint.
82SC Track Car
Old 07-25-2008, 03:44 PM
