Free minder
Gurgling noise at acceleration
Here is the situation: freshly top-end rebuilt 78SC, with ~ 400 miles on it. Since yesterday, I started hearing a popping noise on the right side during WOT acceleration. It almost sounds like back-firing, but less frank. More like a gurgling noise. It sounds combustion related. I am thinking incomplete combustion, or cylinder-head leak. I haven`t noticed a loss of power. What worries me is only one bank of cylinders seems to be doing it. I just hope nothing is going loose in there...Opinions appreciated.
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
First, check that all spark plug wires and terminals are firmly seated--especially on the plugs. Your symptoms may be from something serious or very simple. I had the exact same problem which turned out to be bad (read old) Beru connectors. I replaced the wire set and the engine runs smooth as silk. Good luck and report your findings.
BTW, Beru connectors (especially old ones) can be notorious for bench testing as good, but failing during use. If you check resistance and it meets specs, try tapping the connector while testing. I discovered 3 out of 6 connectors lost continuity when tapped. Yes, they were 35 years old.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 07-22-2008 at 08:35 AM.. |
Free minder
I`ll look into that. My connectors are about 5 yr old aftermarket. Yes, it could be a spark plug not firing well at higher rpms...good idea.
Aurel
abit off center
Your valves aren't too tite are they?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Also, if it really IS gurgleing, it could be air in the oil line on the right side.
Free minder
I set them all at 0.04 when I did the rebuild, and it was fine initially. I could see them getting looser, but tighter would not happen by itself.
Aurel
