Follow me
Hey everyone, I thought my car was on fire this afternoon. First off let me say I don't have AC but I still have all the guts the blower, hoses, Etc. And when it rains and I have the vent fan on It drips a little water in the passenger side floorboard but just a little.
Well this afternoon It started to pouring rain and I mean pouring! So I rolled up the windows and turned on the fans, AC fan and the vent fan. I also had my wipers, radio, headlights and a phone charger in the cigarette lighter on. So I started to smell a funny smell.. kept driving.. I thought it was a car in front of my with some bad exhaust.. kept driving.. about 15 minutes later I came to a red light as soon as I stopped the whole car filled up with smoke. It was coming from everywhere the vents under the dash it was horrible. I immediately turned everything off, and pulled it to a gas station so I could look. I couldn't see anything.. no fire that is. After that I started to diagnose the problem I turned everything back on one at a time to see if if started smoking again. Well when I turned the AC fan back on it started smoking again. Now I have used the AC fan for a year now whenever I have to have the windows up but never had a problem. Has this happened to anyone else? What should I do. Thank you all for any help you can give. Jake Last edited by seymore; 07-17-2008 at 12:53 PM.. Reason: New title |
<insert witty title here>
What did it smell like? Did it smell "electrical", if you know what I mean? (as opposed to oil, exhaust, etc.) Every once in a while I get some smoke emerging from the dash. It hasn't happened often enough for me to trace the source, but it has something to do with the wiring from the turn signal switch, and I believe it might be the high beams. It's a short somewhere, but has never caused a fire in my car. Mighty stinky and scary, though.
It definitely sounds like you've got a short in your fan wiring somewhere. Easiest thing would be to just get under there with a light and trace all the wiring. Not very comfortable or fun, but you should be able to find some place where a wire has frayed, or something like that.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Follow me
Christien, It didn't smell electrical but I'm 99.9% sure it was. Thats why I thought it was exhaust from another car. there was just way to much smoke for it to be exhaust. it smelled kind of sweet a little like antifreeze but burnt. Ill get under there and see if I see anything. Thanks
Might want to disconnect the battery first
Turbo 13b guy
If it didnt smell like anything is burned then its refrigerant from the a/c. I have a leak in one of my lines and when I flip on the a/c it does the same thing. Gauges fog up and the cabin fill with smoke. Nothing is on fire but the r134a does that. Dries your mouth out too. Take it to get the cooling system pressure tested.
1975 911S Targa(333 hp/276 tq) |
Follow me
I dont have AC just the fan.
Turbo 13b guy
So no remnants of refrigerant in the lines or is it all disconnected?
Follow me
There all disconnected.
water in the heat exchangers? steams interiors up fast.
(they're = they are. there = over there, etc.)
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-17-2008 at 03:46 PM.. |
My husband's cabby did this about a week ago... I was driving down the freeway on the way back from a Porsche campout. I turned the fan on for a little ventilation. Odd smell... A few minutes later smoke absolutely boiled out of the vents - thought the car would burn to the ground!!!
The fan that I'd turned on for ventilation is now completely fried... Completely! I suspect that's what happened to you. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Did you got the problem solved, from which blower did the smoke come from?
I had also huge some, when i turned the heat on. and the footwell blowers wont work at all... I also experienced some elektric-like smell at first. Laneco: which fan was the problem? |
Dog-faced pony soldier
Ground your light switch and check your interior/instrument lights for bad grounds/shorts/frayed wires. This is a fairly common problem among older 911s and there are several threads about it - including a few from folks who weren't so lucky.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
This happened to me right after it got done raining very hard here in Houston. It was just steam coming from the footwell heat exits and the dash vents. It really did appear to be white smoke for a few seconds while I was trying to grab the fire extinguisher! |
Now only the motor blower works, all others dont... ?
911-87 mit der 3.6 V-Ram und alles spaß |
Born to Lose, Live to Win
i dont know much about the other blowers, but when my heater motor in the engine compartment fried itself, there was smoke coming directly from it, some melted wires and blown fuse.
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
I think the main problem in my case was the luggagecomparment blower:
![]() http://s216.photobucket.com/albums/cc262/jaskas2/puhallin/ So... where to find a new one? Should i go original, or is there some cheaper solutions? btw. new rims worked out fine:
