supercarrera82's Avatar
Trunk lid will not open...HELP!!
I was replacing the rubber stops on my rear trunk lid and closed the trunk for a second, now the trunk went down too low and is stuck and wont open, i tried pulling the cable while my brother pushed up the trunk lid up but nothing....ne ideas????
Old 08-22-2008, 08:10 AM
Cornpanzer's Avatar
Have your brother push down to relieve the stress on the latch while you pull the cable. If this doesnt work, pull the cable and push down on each front corner independantly.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 08-22-2008, 11:00 AM
Designer King
Paulporsche's Avatar
Search my name and and lid you will find a thread on how I got mine open.
Sorry, I don't know how to post a thread.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-22-2008, 11:02 AM
You mean the engine lid not the trunk lid?
Pull the cable out as far as it will go, put a vise grip on the cable to hold it all the way out (put a towel around it so you don't scratch the paint).
Push down/ pull up on the edges.
If that doesn't work, get a thin metal bar (used a steel ruler) slide it in and try to move the male spring piece back and forth.
Old 08-22-2008, 11:47 AM
