-   -   Do I have the wrong Ball Joints ! (http://forums.pelicanparts.com/porsche-911-technical-forum/421845-do-i-have-wrong-ball-joints.html)
rothaus 07-25-2008 11:42 AM
I have installed these and it looks like they are not correct. When the bolt is not tight, I can move the strut up and down.
These are original Boge strust and this is on a '71 911T.
It looks like the cutout is larger then it need to be for the bolt.
http://forums.pelicanparts.com/uploa...1217011241.jpg
Thanks for any input.
Engelbert
pope 07-25-2008 12:04 PM
Had the exact same problem on Monday. Did you get the 911.341.049.00 Ball Joints?
Chuck Moreland 07-25-2008 12:33 PM
wrong ball joints. Those are 72+
rothaus 07-25-2008 03:20 PM
Thanks ! That make sense now. Now I have to get the right ones. At least I can use these for my '78.
Thanks for the help !
pope 07-26-2008 01:23 AM
My problem was that even though I had the correct ball joints for my year, it seems some PO had changed the struts to a later year. :rolleyes:
Scrappy 07-26-2008 08:05 AM
You can easily tell the difference ... if the ball joint shaft has a rounded relief, it take a bolt and the bottom of the strut will have a slit in it.
The ball joint in the pic has a wedge shaped cutout and takes the double taper pin. The bottom of the strut will not have a slit in it.
rothaus 07-26-2008 09:53 AM
Thank you ! This makes sense now. I have the vertical slot at the bottom of the strut where the ball joint mounts, and the cutout should be round and the same radius as the bolt. When the bolt is tight it clamps the ball joint and the cutout and bolt holds it in position.
Thanks again
