Carmagic.us
rothaus's Avatar
Question Do I have the wrong Ball Joints !
I have installed these and it looks like they are not correct. When the bolt is not tight, I can move the strut up and down.
These are original Boge strust and this is on a '71 911T.
It looks like the cutout is larger then it need to be for the bolt.
Thanks for any input.
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 07-25-2008, 11:42 AM
1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Had the exact same problem on Monday. Did you get the 911.341.049.00 Ball Joints?
'70 911E Coupe, Webers 40IDA
Old 07-25-2008, 12:04 PM
Chuck Moreland's Avatar
wrong ball joints. Those are 72+
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-25-2008, 12:33 PM
Carmagic.us
rothaus's Avatar
Thanks ! That make sense now. Now I have to get the right ones. At least I can use these for my '78.
Thanks for the help !
Old 07-25-2008, 03:20 PM
pope's Avatar
My problem was that even though I had the correct ball joints for my year, it seems some PO had changed the struts to a later year.
Old 07-26-2008, 01:23 AM
Scrappy's Avatar
You can easily tell the difference ... if the ball joint shaft has a rounded relief, it take a bolt and the bottom of the strut will have a slit in it.
The ball joint in the pic has a wedge shaped cutout and takes the double taper pin. The bottom of the strut will not have a slit in it.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 07-26-2008, 08:05 AM
Carmagic.us
rothaus's Avatar
Thank you ! This makes sense now. I have the vertical slot at the bottom of the strut where the ball joint mounts, and the cutout should be round and the same radius as the bolt. When the bolt is tight it clamps the ball joint and the cutout and bolt holds it in position.
Thanks again
Old 07-26-2008, 09:53 AM
