engine harness plug Identification
I removed my CIS to replace the airbox. I am getting everything back together now. I just discovered the fuel pump plug that plugs into the back of the fuel distributor plate is identical to the plug that goes to sensor just below the throttle body. Now Im not sure which plus into which. Is there any way to know for sure??
2004 SRT-10 Viper powered ram
2006 Hummer
1989 Mustang supercharged 5.8 351 TKO600 5 speed
1987 Buick Grand National
1979 Porsche 911 SC work in progress
Old 07-26-2008, 10:50 AM
DSPTurtle's Avatar
They should be too different colors. On mine one is green/blue and one is tan or black, can't remember. But the green goes to green. If all else fails, and this is going to sound silly, look at how the wires want to bend. They should give you and indication of which way they want to go. I also think that they are different lengths so one should not reach the wrong connector without much tugging and pulling. I call it the zen of wire routing. They should have a "natural" bend to them and you will be able to feel which connector is correct.
If that fails, a Bentley's shoudl have a pin out and you can buzz the wires to figure it out... ugh.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-26-2008, 12:20 PM
