Targa Body Brace
Anybody have experience with a targa body brace. They mount between the upper seat belt mount on the targa pillar and the lower seat belt mount on the floor. They are supposed to stiffen up the body, though I'm not sure how much they would improve handling.... anybody?
joe ------------------ '69 911 E Targa - aka "RoxiE" |
abides.
This is definitely a YMMV item. There are already a few threads discussing it, the gist of which are that some people like it, some people say it does nothing. Having a lighter car, I bet you might notice it more.
That said, JMPRO is a good guy that stands behind his products.
Graham 1984 Carrera Targa |
East Coast R Gruppe
As stated above, there are a few threads that discuss this product. Some support, some say they do little or nothing. I installed them in my targa, "felt" that it stiffened the car, but can't say for sure.
Do a search and you will get some good information/ opinion on what they will or will not do. Worth a read before making a decision, IMO.
OGRP3 RGRPNE |
thanx
shoulda searched before shooting
78 in a '71
I have searched this subject before but did not find what I was looking for, i.e. when I put my targa on stands under the torsion bar ends/covers, the gap between the rear edge of the door and the front edge of the rear fender widens, especially at the top. Does anyone know if the brace would imrove this situation.
thanks Tom
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
Jerry JM PRODUCT DESIGN |
78 in a '71
Thanks Jerry!
Tom
I got em, great product.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
JMPRO has a money back guarantee? That's good business!
With a 69 model, it looks like I will have to tap a hole in the inside sill to get these mounted. Any tricks to doing this. Sounds to me like seats and carpets have to come out. Do reinforcements at that point need to be welded in?
THE IRONMAN
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Virginia Rocks!
I've had a set installed for 3 years. I honestly don't know if it makes a difference or not since I don't recall how it used to be. I think at the time I said it made a difference...search on my name, I've posted about it. I have lift a home and I get some body flex when on the lift. (the door is a little tough to open/latch.) I guess it would be worse if I removed the braces.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
My other thought is that if you install a lower mounting hole you could move the hole futher forward to provide for a greater angle on the bar that probably would enhance the performanceof the brace. You would need to get longer bars but I am sure I could provide those. Jerry Last edited by JMPRO; 07-26-2008 at 09:09 AM.. Reason: another thought |
I have used these "Rivnut" fasteners in many similar applications. You donot need the tool if you are only mounting one or two of them. Just use a bolt with a couple of washers to compress the nut. In your application I would attach something like a 1/8 thk x 2" x 3" piece of steel to double the stress area.
http://www.enfasco.com/frame4.htm
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
I have used these "Rivnut" fasteners in many similar applications. You do-not need the tool if you are only mounting one or two of them. Just use a bolt with a couple of washers to compress the nut. In your application I would attach/glue/screw/weld something like a 1/8 thk x 2" x 3" piece of steel to double the stress area.
The rivnuts I used on another application but would be practical for this use also were so heavy duty that if you tried to install them with anything but the tool you could ruin a few before you could get it right. Ruining a few nuts is not a big deal since they are cheap but when you have one part in and part out and it has to be removed, that can be a real mess.
I will look up the part number for the insert and tool that I used. Jerry |
Here is a pic of the set up I put together for a cab. I used some brackets I had and mounted them to the floor rather than the sill. The brackets used 2 bolts and rivnuts for a very secure mount. This installation could work in an older Targa and actually increases the angle of the bar for better triangulation although it can make it harder to get in and out of the car. I decided not to market this application because of the higher cost {extra brackets, bolts, rivnuts, special tool}
and that fact that the rivnut installation is not very DYI friendly. This install also requires that holes be drilled and that puts a lot of people off. Jerry
