-   -   early 911 engine number "help" (http://forums.pelicanparts.com/porsche-911-technical-forum/422182-early-911-engine-number-help.html)
carrera turbo 07-27-2008 06:53 PM
im looking at adding another 911 to the stable. the car is a project and im trying to figure out what the motor has webers on it and wondering what year and displacment it is?
engine # 61031014
thanks for the help
TargaFlorio 07-27-2008 06:59 PM
Are you sure you don't have too many digits?
6103001 and onwards would be a 1970 European 911T with Sportomatic Gearbox
This would make it a 2.2L with 2 triple choke Zenith TIN 40 Carbs
Cheers,
http://nicolashunziker.com
carrera turbo 07-27-2008 11:29 PM
to many numbers?
i read the numbers off twice and that is what we came up with. i read and someone else wrote so maybe there was a mistake somewhere?
the car is definitely european all gages and under hood writing is in german.
but it is not a sportomatic maybe it was at once or the engine is not origanal to the car.
but thanks that helps.
where do you find these numbers i have search quit a bit and have come up short.
thanks
carrera turbo 07-28-2008 01:16 AM
looks like the engine number is as fallows
#6103101 i said star at the end and she wrote 4
make more sense?
thanks
TargaFlorio 07-28-2008 06:10 AM
6103101 would still fall under the category of 1970 European 911T with Sportomatic.
VIN for that engine fall between 9110110001 and 9110112545
What car is it in?
Cheers,
