SC oil pressure sending unit leak
When I recently started my heater backdate on my 83, I must have bumped the oil pressure sending unit in the process, loosening it up a little. It started my first official oil leak. I have tried tightening it up a tad and it helped, but I do not want to overtorque it. I noticed it at work today and I loaned my Bentley out. Is there a torque value for this fitting? Is this thing using an o-ring seal? I am wondering if the o-ring tore or was damaged when it was bumped loose?
Shane - 1984 928S |
You have a Porsche AND a Bentley? And you let other people drive it? Wow.
Now that is funny tcar - thanks for the laugh...
Shane - 1984 928S |
this Bentley... (in case anyone new reads this)
Shane - 1984 928S |
oh... never mind...
AutoBahned
pipe thread - tapered
can you get a torque wrench in there? |
Don't know really, have not tried yet... but I do have a metric set of crows feet and thought I could reach it with those and an extension...
Shane - 1984 928S |
AutoBahned
that will change the torque value - I would just tighten until it stops leaking -- slowly
OK, will try that route. Thanks
Shane - 1984 928S |
Shane,
I think they use those soft crush washers here. Where does it leak? the sensor is attached to a housing and the housing also has a bolt. Does it leak at the housing or right where the sensor attaches? In either case if it has those soft crush washers I'd get new washers.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
OK< thanks Sal. It looks like I should be able to unbolt this without any big todo. I do not need to drain oil down at all do I? This should give me a better idea of what I have going on anyway...
Shane - 1984 928S |
Just un-bolt it should not leak much.
AutoBahned
if it is mounted into a block like on a Carrera be VERY careful - search threads on that & do what Jim Sims has posted.
