9.8 3.0 p/c where to fine a set for my rebuild
Is Andial the only source for these elusive piston and cylinders?
currenly have a 1978 3.0 in my 1975 Carrera. Thanks, Craig |
Also look into Nickies as an alternative to Mahles if you want something other than the standard configurations http://www.lnengineering.com/
You may find it easier to get a whole newly manufactured set rather than an OEM set. When I was looking to replace my one blown piston it took me months to find the right one and then it cost me $250... used... I never found a whole set, but I have seen 1 or 2 since then.
Best regards, Michael |
Thanks, for info. These 9.8 's P/C's are expensive!
But if you want the 9.8, 3.0 I too would go with ln engineering. Everything I've seen of theirs was pure top notch. |
JMO but if you are rebuilding a 3.0 w/ no constraints by class rules, you might as well use 98mm Motorsports Mahles, they aren't that much more expensive |
Where do you find the mahle motorsports 3.0 or the In eng. for that matter?
thanks, I am buliding a street motor to run on 91 oct. gas with some open track days. If a 3.2 conversion will work with 91 gas I would also go that way. I have a 78 3.0 with matching heads and runners |
Look on the next page from where I sent you last time
You don't want a single plug 9.8:1 98mm bore on California's piss-water 91 octane gas.
Tom |
