9.8 3.0 p/c where to fine a set for my rebuild
Is Andial the only source for these elusive piston and cylinders?
currenly have a 1978 3.0 in my 1975 Carrera.
Thanks,
Craig
Old 07-28-2008, 09:13 PM
Bill Verburg's Avatar
here
Bill Verburg
Old 07-29-2008, 04:36 AM
Also look into Nickies as an alternative to Mahles if you want something other than the standard configurations http://www.lnengineering.com/
Robert
Currently Porsche less (but the wife has 2)
Old 07-29-2008, 06:38 AM
Less brakes, more gas!
euro911sc's Avatar
You may find it easier to get a whole newly manufactured set rather than an OEM set. When I was looking to replace my one blown piston it took me months to find the right one and then it cost me $250... used... I never found a whole set, but I have seen 1 or 2 since then.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-29-2008, 07:15 AM
Thanks, for info. These 9.8 's P/C's are expensive!
Old 08-01-2008, 11:03 PM
DUK DUK is offline
DUK's Avatar
That's why I went with a 3.2.
But if you want the 9.8, 3.0 I too would go with ln engineering. Everything I've seen of theirs was pure top notch.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 08-02-2008, 04:30 AM
You expected otherwise?
JMO but if you are rebuilding a 3.0 w/ no constraints by class rules, you might as well use 98mm Motorsports Mahles, they aren't that much more expensive
Bill Verburg
Old 08-02-2008, 06:34 AM
Where do you find the mahle motorsports 3.0 or the In eng. for that matter?
thanks,
I am buliding a street motor to run on 91 oct. gas with some open track days. If a 3.2 conversion will work with 91 gas I would also go that way.
I have a 78 3.0 with matching heads and runners
Old 08-02-2008, 11:17 AM
Look on the next page from where I sent you last time
Bill Verburg
Old 08-02-2008, 01:33 PM
Hilbilly Deluxe
emcon5's Avatar
You don't want a single plug 9.8:1 98mm bore on California's piss-water 91 octane gas.
Tom
82 911SC Coupe
GTI Cup #43
Old 08-02-2008, 04:47 PM
