Carmagic.us
rothaus's Avatar
show me some pictures of you 4 point harness in early 911
I'm looking for some optionts to mount the 4 point harness in my '71 911 for AX.
Can you post some pictures how you mounted yours, especially the mounting point tp the back.
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 07-29-2008, 04:34 PM
"farking Porsche hero"
Rich Lambert's Avatar
Here's how I mounted the harness in the rear of my '66. It's bolted through the package shelf and the bolts are backed by 2"x12"x3/8" steel bars.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 07-29-2008, 08:16 PM
Rich, I like your seats.
Could you post a pic of them and give me some details (model)?
Are they confortable?
Old 07-30-2008, 01:52 AM
mph911
Matt Hart - Instagram @the_escape_road
Old 07-30-2008, 02:35 AM
mph911
BTW. I think I have the same seats as Rich. They are ST Rallye's. THey are very comfortable , and supportive. Also very light compared to my stock 69' seats.
Old 07-30-2008, 02:39 AM
Thanks Matt,
i don't think they are the same seats actually. to me, they look more like these:
Old 07-30-2008, 03:08 AM
Carmagic.us
rothaus's Avatar
Thanks Guys !
This is great ! Now I have some options, I Think I go with the option on top of the panel with the reinforcement from the bottom.
mph911, did your car had already some mounting holes in the bottom, or did you add some with reinforcement ?
I will post some pictures after I have istalled mine.
BTW: I had to modify the seat brakets from the corbau seats because they were to high. I cut them apart and insert a one inch spacer on front and a 1 1/2 " spacer at the rear side. Now its much better. I will post some pictures.
Engelbert
Old 07-30-2008, 04:36 AM
mph911, nice seats!
Mine are GTS Nurburgrings...very comfy and good support.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 07-30-2008, 05:37 AM
briancoates's Avatar
Don't forget to check regulations especially if the car is going on the track. From memory over here the rear mounts must be below the horizontal but no more than 45 degrees below the horizontal. Don't have the rule book handy to check exact requirements. Even if the car is not going to be used on the track they list these sort of specs for a reason... "Safety". Mounting points on a rear parcel shelf have been known to tear the sheet metal if only a lower plate is used. Do some proper research.
Gotta love harnesses.
Old 07-30-2008, 05:38 AM
One other thing I recall from my vintage racing days...it was a requirement to have at least a 3" washer under the bolt. I didn't do that because I figured the 2"x12" bar would spread the load out over a wider area (I do have 3" washers under the belt bolts). It's not a perfect solution, but it's way better than the stock restraint system that would basically try to cut you in half.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 07-30-2008, 05:58 AM
Guys, you might find this thing usefull (we are discussing the same thing in the french 911.net forum)
Rich, your seats are really really nice. they are a perfect mix between a race and road "spirit"
Old 07-30-2008, 06:17 AM
I really, really, hope you mean 5 point ( minimum)...not "4-point"......
Right?.....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-30-2008, 01:14 PM
Peter Zimmermann's Avatar
These are PCA Club Race legal belts - they are six-point and the sub strap that you can't see mounts to the floor anchors with the lap belts. Car is a '69 912 updated to 2.2 liter 911E specs.
Keep the Shiny Side UP!
Pete Z.
Old 07-30-2008, 04:52 PM
resident samsquamch
sand_man's Avatar
Originally Posted by Rich Lambert View Post
mph911, nice seats!
I'm amazed at how spacious the interior looks without a center console! I had mine out for a short while, but the look seems to fit an early car better...or a track car.
-jeff
Old 07-30-2008, 05:01 PM
Carmagic.us
rothaus's Avatar
Here are the pictures of the modified Corbeau seat brackets.
I lowered the from by 1 inch and the rear by 1.5"
Detail from the other side
Cheers
Engelbert
Old 07-31-2008, 09:49 AM
Right?.....
Actually, Schroth makes a 4-point belt (with their ASM designation) that is safe, as it is designed to lengthen one shoulder strap in a crash, which mimmicks the operation of a 3-point belt. Otherwise, I agree with you.
The belts shown attached to the rear shelf in the picture earlier in this thread might be better off if they were crossed. (That's a really nice looking car, by the way.) There are some excellent mounting instructions available from Schroth that should be required reading for anybody headed down this path. Look for them on the their web site. Here's a link:
http://www.schrothracing.com/
JR
Old 07-31-2008, 10:23 AM
