Headlight washers. Can I remove this pump?
I deleted the headlight washers/sprayers in my front bumper and I would like to clean up the plumbing in the front.
Can someone please confirm that the parts that I have so skillfully pointed to with the red arrows are in fact part of the headlight washer system? Can I remove these two lines and this big ugly pump and still have the windshield washer system function correctly?
Also, the relay looks brand new. Is this for the washer system?
Old 10-07-2008, 06:16 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
subd
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 10-07-2008, 06:17 PM
abit off center
cgarr's Avatar
I took mine out, windscreen is a separate pump, its that little one to the left there next to the relay. What year car? it works the same but mine is in the fluid tank its self.
______________________
Craig
G2Performance
Old 10-07-2008, 06:47 PM
Mine is a 1978.
Old 10-07-2008, 07:18 PM
Walt Fricke's Avatar
Ringmaster
You have correctly identified the parts - the headlamp washer pump and the relay to control it. You can remove the relay and the pump, and plug the hose coming in to the pump from the fluid tank, and all will be well.
I went to the trouble of installing this system at one time on my car (Euro '77, now in SC trim). Had a racing wreck, got a new bumper (among other parts) and found it had different sized holes for a later, flush mount washer. Then the used pump I had acquired failed - plastic hose connection tube broke off, epoxy repairs failed. So my new squirters are just hole fillers. But I never used them anyway.
Walt Fricke
Old 10-07-2008, 09:07 PM
