Living up to the name
VroomGrrl's Avatar
And so it begins...Fuse Problem? Or??
I was at a stop light and reached down to the elec controls on the left side of my seat to tweak my seat adjustment. I had the AC running. I pressed the switch and the seat moved a bit then stopped. And the AC blower stopped flat. Now neither of the seat adjustment switches nor the AC blower is working.
So has anyone else had this combination of failures?
I'm hoping this is a fuse thing? I took some pictures of my fuse box but they came out crappy. I'll go out right now and take some better pics but here's what I have for now. I'm posting these pics as links to flickr and if you click the link you can go see a much larger version of each image:
fuses2
fuses 1
fuses3
Old 07-31-2008, 11:46 AM
It is strange that someone put all red relays in your panel. From what I remember the red ones are usually for the fuel pump. I think they were supposed to be higher quality than the black ones so I guess it is a good thing.
Old 07-31-2008, 02:25 PM
Send a message via AIM to fintstone
Kathy...you are killing me! I just spent a half hour looking for my schematic on your car...and 15 minutes trying to read the tiny print with a magnifying glass....as I came back to this thread after tracing the wiring to proudly tell you which fuse was the problem and why; I see you have another thread on the same problem where you fixed it hours ago. Try to keep your troubleshooting of a problem to a single thread so we are not helping fix an old, solved problem.
Congrats on successfully fixing your first problem.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-31-2008, 09:27 PM
