just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
starting [problem
I was driving home the other night and the car just died on me.
as if it had run out of fuel. no weird noises or lights or anything out of the ordinary.
just a loss of power.
I have a spare working relay I plugged in under the seat.
no change.
I tried a fuel pump from napa, and it wouldn't start. the pump made some noise for a while and then stopped
I got a new coil. put it in with the napa pump still in place. nothing happened.
I took out the napa pump, and put the original pump back in.
the car started right up, settled into a solid idle and revved great.
about 3 minutes later the idle got rough and the car died again.
tried to restart it and got nothing the first time.
waited a couple minutes and it started but ran very rough and then died again.
I let it sit while I was working and went to try again.
turned the key and the coil didn't make a sound at all1
the engine turns over, builds oil pressure but just won't start.
is something killing the coil on me?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 08-29-2008, 04:18 AM
red 2.7's Avatar
Sounds like fuel delivery have you changed your filters lately?
Wally
Old 08-29-2008, 04:42 AM
just me
paulgtr's Avatar
in november
Old 08-29-2008, 04:44 AM
just me
paulgtr's Avatar
I've been doing tons of searches and can't seem to find anything where the car died and then started again with a new coil and then died again.
any ideas?
Old 08-29-2008, 08:31 AM
For the car to run you need
  1. Fuel
  2. Compression
  3. Ignition
Do you have those?
#3 is the easiest to check for.
Rick
88 Cab
Old 08-29-2008, 08:38 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
does the car have a "green wire" , AKA dizzy trigger wire? could it be in bad condition?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 08-29-2008, 11:11 AM
I assumed a 3.2 was a DME car
Rick
88 Cab
Old 08-29-2008, 11:15 AM
i was unclear about his setup, thats why i asked. on my car, that would be the first thing i checked if i was having those symptoms after replacing coil, but im only familiar with the 3.0
1983 911sc
Old 08-29-2008, 11:17 AM
just me
paulgtr's Avatar
when i first installed the coil it made the noise it was supposed to when I turn the key on bfore starting it up.
started right up
now there is no noise from the coil
I went and pulled all the fuses and looked them over, none are broken or in abnormal condition.
nothing smells burnt or melted.
Old 08-30-2008, 07:55 AM
