clutch pedal needs viagra
recently rebuilt my cluster and the clutch pedal rests about 1/2 way down. it still functions well but causes me to move the seat too far forward granny style....
when i did the rebuild i did not replace the large spring, is this my problem??? it still seemed to be in ok shape. any advice would be great! thanks |
...you want to make the clutch pedal harder? How unusual...
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 08-11-2008 at 08:19 AM.. |
move the adjusting nuts that attach the cable to the trans bracket a few turns closer to the rear end of the cable sheath to raise the pedal engagement point.
thanks john!
I had a similar problem. My roll pin worked itself half way out pedal was sloppy and had trouble shifting.
Mike '99 Isuzu VX, 2005 Audi A4 1.8T Quattro '96 BMW 328ic '73 911T Targa SOLD www.flickr.com/photos/fenderbender813 |
jon,
It always helps to know the YEAR and MODEL of your car. |
