California, SSI, No Cat, and Smog
Say that you have have an '83, vanilla 3.0, SSI, no cat, valve adjusted, cap-, rotor-, plugs all new.
You also have the Gunson analyzer. You have a blind smog technician. The 60 million question would be: assuming there are no visual check, what air-fuel ratio should I have to pass California smog? My guess is 2.0. What is yours? Your input is much appreciated. |
2% is OK for Willow Springs however!
Keep the Shiny Side UP! Pete Z. |
