-   -   Relocate A/C Controls (http://forums.pelicanparts.com/porsche-911-technical-forum/423605-relocate-c-controls.html)
Elombard 08-06-2008 05:12 PM
Wow that is a nice box, I wonder if the PO fabbed it or found something from another car that worked?
rusnak 08-06-2008 05:17 PM
yeah, if you can find the P.O. ask him if he contracts out his work, cause from the looks of it, he has skills.
wcc 08-06-2008 05:32 PM
I'm not sure to either one of those questions but I can tell you that 99% of the paperwork that I have is from Precision Motion Kravig Engineering in Riverside, CA. Maybe that's a good place to start because I don't think this guy did anything on his own based on the amount of paperwork.
rusnak 08-06-2008 06:06 PM
it would be on one of their invoices. Any other trick bits in the car?
DG624 06-27-2012 11:53 AM
I would remove the console since it is broken and does not look great but I was wondering where to put the emergency flasher, A/C, radio fader... If there was a nice small panel like the one shown then it could fit a variety of things. I guess I could eliminate the lighter and use the empty plug space for some items and put the A/C between the seats.
Now I would like to eliminate the headlight washer, sunroof switches with blanks. Has anyone done this?
RSTarga 06-27-2012 12:56 PM
How did he run the temp sensor to the evaporator? Thats a really long run for that hard line. The box looks like for one of those aftermarket a/c units that are used for hot rods.
DG624 09-19-2012 04:12 PM
Has anyone done a relocation of their console knobs (flasher, rear window heater) to the dash?
wgirardot 09-19-2012 05:44 PM
Originally Posted by wcc (Post 4103681)
One of the previous owners relocated them to here...
http://forums.pelicanparts.com/uploa...1217979004.jpg
Nice. I started to do just that, but too much work pulling carpet, etc. and hacking into the tunnel. Went back to original console set-up but rewarded myself with installing a lamp to let me know when compressor is activated. One wire to switch blade contact on thermo control and one wire to ground.
Bill
DG624 09-21-2012 07:41 AM
I already replaced the entire carpet and know the problems with removing and replacing the console. I just don't think it does much...just a knob holder. If I can relocate these knobs then it would clean up the interior.
