3 liter cams and oil pressure...
Two questions:
1) The oil pressure on my '77 Carrera 3.0 drops to an indicated zero at idle when hot (90 to 100 deg. C) I still get 4 bar when revving over 4000 rpm. Should I be alarmed?
2) Are Carrera 3.0 cams the same as later SC cams?
Thanks!
Bill
Old 08-08-2008, 05:31 PM
Bill,
Without knowing what oil and viscosity you use, its tough to tell you anything definitive but offhand, I would not be alarmed with 4 bar @4K.
SC & Carrera 3.0 cams are identical. They are simply timed differently.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-08-2008, 05:57 PM
I'm using 20/50 Castrol GTX. RE the pressure, I am concerned with the indicated 0 at idle when hot.
So, the Carrera 3.O has cam timing for more top end power?
Thanks,
Bill
Old 08-10-2008, 11:52 AM
Thanks,
Bill
Yes, in a general sense, although the 911SC had different timing in certain years and certain markets and, for some of those, the timing was identical to the Carrera 3.0.
JR
Old 08-10-2008, 12:00 PM
Thanks,
Bill
If it were my car, I'd ditch the Castrol GTX for Brad-Penn 20w-50.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-10-2008, 02:27 PM
Max Sluiter
Flieger's Avatar
Yes, go Brad Penn 20/50
I just did this a week ago, switching from Castrol GTX. Your engine will thank you. I was enlightened by Mr. Navarro's Ultimate Motor Oil thread.
Old 08-10-2008, 03:50 PM
