-   -   When did the A/C systems start getting good? (http://forums.pelicanparts.com/porsche-911-technical-forum/423999-when-did-c-systems-start-getting-good.html)
TerryBPP 08-07-2008 12:36 PM
Living in SWFL A/C is a big deal. My old 76' had a crap system. When did the system start being reliable and cold? Late 80's or was it not until the 964's came out?
Jgordon 08-07-2008 01:39 PM
964s.
Zeke 08-07-2008 01:40 PM
993's even better.
gr jetson 08-07-2008 01:44 PM
How does the air differ in the 964 and 993? I thought the set-up was the same, but I'm here to learn.
Thanks!
Cordially, Greg
Zeke 08-07-2008 01:46 PM
Thanks!
Cordially, Greg
Might be some subjective information I'm passing along. That's what people tell me.
mthomas58 08-07-2008 01:58 PM
Nothing wrong with the A/C in a 3.2 if your willing to throw a little $$$ at it. OK, alot of $$$ :D
Mike Andrew 08-08-2008 10:08 AM
Or a 3.0 if you are willing to throw those bucks.
kick7ca 08-08-2008 10:28 AM
I had factory a/c in my 89 3.2 recharged with R12 and it's ICE COLD.
ZAMIRZ 08-08-2008 10:31 AM
993 or you can drop $3K on a Rennaire installed.
964 A/C still mediocre in SoCal summer heat.
KFC911 08-08-2008 03:18 PM
The a/c on my Carrera was fairly decent (when charged) for NC (get's pretty hot here too) although I only used it a couple of times and I'm just not an a/c person so I removed it. When I lived in Jax many years ago, I had a brand new Supra that sat in the sun all day, and I thought the a/c sucked on that car too, until I moved back to NC. IMO, my Carrera's stock a/c would probably have been sufficient for Fl. as long as the car didn't bake in the sun all day...if it bakes, I doubt it :).
Mr.Puff 08-08-2008 03:25 PM
My '84 911's A/C was so bad in NorCal that I just took it out...
dmwallace 08-08-2008 03:48 PM
After replacing the evaporator, blower fan and compressor along with adding a ProCooler plus a center vent to my '89 I became convinced that it would have also required replacing both condensers (and fans for the rear condenser) to have a chance at acceptable A/C for this part of the country.
Upgrading to a 993 turned out to be a good A/C fix along with the other model improvements.
Regards,
KFC911 08-08-2008 03:55 PM
I must live in the cooler part of Greensboro David...the a/c in my truck hasn't been used either but I haven't bothered to remove it to save weight :).
