When did the A/C systems start getting good?
Living in SWFL A/C is a big deal. My old 76' had a crap system. When did the system start being reliable and cold? Late 80's or was it not until the 964's came out?
964s.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
993's even better.
How does the air differ in the 964 and 993? I thought the set-up was the same, but I'm here to learn.
Thanks! Cordially, Greg
Greg Jetson 1987 Carrera Coupe Venetian Blue 1984 Carrera Targa Slate Blue 1979 911 SC Slate Grey (sold, but it irrevocably launched me down the path) |
Throw it on the ground!
Nothing wrong with the A/C in a 3.2 if your willing to throw a little $$$ at it. OK, alot of $$$
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Wildman Emeritus
Or a 3.0 if you are willing to throw those bucks.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
I had factory a/c in my 89 3.2 recharged with R12 and it's ICE COLD.
993 or you can drop $3K on a Rennaire installed.
964 A/C still mediocre in SoCal summer heat.
Amir '83 911SC |
The a/c on my Carrera was fairly decent (when charged) for NC (get's pretty hot here too) although I only used it a couple of times and I'm just not an a/c person so I removed it. When I lived in Jax many years ago, I had a brand new Supra that sat in the sun all day, and I thought the a/c sucked on that car too, until I moved back to NC. IMO, my Carrera's stock a/c would probably have been sufficient for Fl. as long as the car didn't bake in the sun all day...if it bakes, I doubt it
The Puff.
My '84 911's A/C was so bad in NorCal that I just took it out...
'70 CT1B '11 GTS 300 Super |
After replacing the evaporator, blower fan and compressor along with adding a ProCooler plus a center vent to my '89 I became convinced that it would have also required replacing both condensers (and fans for the rear condenser) to have a chance at acceptable A/C for this part of the country.
Upgrading to a 993 turned out to be a good A/C fix along with the other model improvements. Regards, David
1997 Carrera 993 coupe - Slate Grey Metallic / Classic Grey 1989 Carrera 3.2L coupe - departed - Stone Grey Metallic / Silk Grey |
I must live in the cooler part of Greensboro David...the a/c in my truck hasn't been used either but I haven't bothered to remove it to save weight
