3 liter cams and oil pressure...
Two questions:
1) The oil pressure on my '77 Carrera 3.0 drops to an indicated zero at idle when hot (90 to 100 deg. C) I still get 4 bar when revving over 4000 rpm. Should I be alarmed? 2) Are Carrera 3.0 cams the same as later SC cams? Thanks! Bill |
Bill,
Without knowing what oil and viscosity you use, its tough to tell you anything definitive but offhand, I would not be alarmed with 4 bar @4K. ![]() SC & Carrera 3.0 cams are identical. They are simply timed differently.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I'm using 20/50 Castrol GTX. RE the pressure, I am concerned with the indicated 0 at idle when hot.
So, the Carrera 3.O has cam timing for more top end power? Thanks, Bill |
If it were my car, I'd ditch the Castrol GTX for Brad-Penn 20w-50.
Max Sluiter
Yes, go Brad Penn 20/50
I just did this a week ago, switching from Castrol GTX. Your engine will thank you. I was enlightened by Mr. Navarro's Ultimate Motor Oil thread.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
