FenderBender's Avatar
Having a bad day!!
This sucks, It could be worse but it still sucks. My Battery install was not a good idea. If you guys see me do anything else stupid feel free to tell me about it.
This
Equals this after enough bumps.
Of course the hood cable melted and would not open the hood. I managed to get it open and used a Extinguisher on it. Dry chemical type. Now what? I am going to shop vac as much as possible. What about the effects of this on the fuse box etc?
Mike
'99 Isuzu VX, 2005 Audi A4 1.8T Quattro
'96 BMW 328ic
'73 911T Targa SOLD
www.flickr.com/photos/fenderbender813
Old 08-12-2008, 05:59 AM
Looks like the cable tube was rubbing on the positive post. Cable did not melt it melted the weld by the latch.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 06:34 AM
Danny_Ocean's Avatar
Wow. That sux.
There's quite a few threads here on building a battery tie-down tray out of sheet aluminum (or even a cutting board!). You also should use proper terminal covers for the battery posts.
Old 08-12-2008, 06:44 AM
Elombard's Avatar
Holy cow that is a powerful battery. Sorry, take a breath and get prepared to make a fun project out of it, it does not have to be expensive just well thought out and planned. Take time on the fabrication. Now you can plan a trunk detail and paint in the future :-)
Is the battery toast?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-12-2008, 06:47 AM
Battery is fine, drove it home. This is a sealed battery and is going to be mounted on its side with proper covers. I went with the big battery when I switched from two battery's to one.
I am searching for cleaning up the powder. I read it is caustic, do not know if i should hoe it down??
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 06:53 AM
UnRegistered User
billybek's Avatar
I think you are on the right track with vacuuming it up first...
Get rid of most of it then damp rag it rinsing often, then do a good scrub after most of it is gone..
Make sure you have a good bag in the shop vac, perhaps a hepa.
Some of that carbon might come off with a bit of elbow grease. Did it heat through the hoods outer layer of paint?
Bill K.
Old 08-12-2008, 06:59 AM
No paint damage that I know of yet. Mostly black smoke from the carpet. Just worried about water and the dry chemical reaction.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 07:05 AM
kneedragger302's Avatar
Dude that looks firmilar, I have experience rebuilding front wiring harnesses...Remember....Don't use your horn!
Old 08-12-2008, 07:21 AM
Friend of Warren
Try to get as much of it up as you can when it is still a dry powder. Once wet it will turn as hard as concrete when it dries.
Kurt V
Old 08-12-2008, 07:51 AM
Come on over. My horn is just fine.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 07:53 AM
I sucked up every thing that I could. It was only two small bursts with the extinguiser. I then blew it out and hosed it down. Really, Really good. Now time to start repairing and cleaning, So I can keep driving her untill winter hits us agaiin.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 07:56 AM
GothingNC's Avatar
Ouch
Glad to see that the Porsche did not go up in flames.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 08-12-2008, 08:07 AM
Thanks guy's. The evap line melted at the charcoal canister, could have been a lot worse.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 08:29 AM
joe payne's Avatar
Two words: THAT SUCKS.
jtp911
Old 08-12-2008, 09:15 AM
I've done stupider stuff. You'll recover. Live and learn.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 08-12-2008, 09:27 AM
gigem75's Avatar
x2 me too!
Old 08-12-2008, 09:46 AM
Fast Corners's Avatar
Everyone has done something they regretted later. Just be glad you noticed it and did not loose the whole car.
The trunk cable guide tube does not need to be fully intact for it to still function. If you can not reform it back to a tube shape, you could always cut out the damaged section and just leave that portion open.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 08-12-2008, 11:10 AM
Model Citizen
herr_oberst's Avatar
+1
Save the link and send it off to anyone who writes in to ask if an onboard fire extinquisher is a good idea.
Old 08-12-2008, 11:13 AM
+1
I am glad I had my extinguisher with me.
I got most of it cleaned up, repaired the wires and JB welded the release tube in place. Changed the battery mounting and got the PROPER covers.
Checked all the electrical and every thing is good. Now I need a hood cable and carpet.
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-12-2008, 02:39 PM
dshepp806's Avatar
frikin' yeouch!!!!!!!!!!!
She (battery) needs to VERY still (which you now know) .......ouch. You CAN get this squared away...sorry it happened...
My best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-12-2008, 03:03 PM
