16 X 9s on early car; ride height question.
I have a set of 16 X 9s on the back of a 1973 w/ SC flares.
Tires are 245 / 45 ZR 16s. The ride height is 24 1/4".
The wheels are rubbing when cornering. I realize I can raise the car a bit. Would I be better served by changing to a 15" wheel for the long run. I want the car to be low.
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 08-12-2008, 10:08 AM
IROC's Avatar
Generally speaking, this tire/wheel combination should work without a lot of problems. The fact that you're only (?) seeing rubbing when cornering sounds like an issue with spring rate and or roll stiffness. In other words, if the car is really softly sprung, maybe you're getting enough body roll to allow some contact that most people don't experience.
Also, alignment numbers and even tire brand could be an issue. Not all 245/45s are the same size.
My 2 pfennigs.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 08-12-2008, 11:03 AM
Bill Verburg's Avatar
Your car looks really nice!
Where is it rubbing?
when is it rubbing? rights? lefts? bumps?
standard Fuchs 9x16 ET15?
tire size?
Bill Verburg
Old 08-12-2008, 11:40 AM
Preventing body contact via increasing torsion bar or sway bar dimensions in a street car won't prevent that one time when the vehicle encounters that certain dip in the road. Most of the suspension travel will be taken up with that simple car maneuver.
Are there spacers behind the wheels? Are these factory Fuchs? As suggested, you shouldn't normally have any clearance issues with SC flares.
Sherwood
Old 08-12-2008, 11:51 AM
Just to round-out the options...you may consider running more negative camber .
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-12-2008, 01:33 PM
Also check if it is rubbing at the fender lip, probably you can roll the lip.
Nice Car !
Old 08-12-2008, 02:07 PM
Abbreviating the rear fender lip doesn't provide much relief. Rather unfortunately, any rubbing of the rear fenders from any ride height issues happens about 2" above the lip due to the camber curve of the rear suspension. The resultant burn-through is cresent-shaped.
Sherwood
Old 08-12-2008, 03:36 PM
tire size?
Thanks for all input. I am still sorting the car minor tasks major headaches!
245 45 ZR 16
Driver side of the car is rubbing w/ slight dips & rubs hard on curves.
75 911M 2.7 MFI
19 991.2 S
25 992.1 GT3RS
Old 08-12-2008, 08:30 PM
Bye, Bye.
Scooter's Avatar
What is the brand of tire? Some manufactures are actually larger than others.
Elvis has left the building.
Old 08-12-2008, 08:46 PM
wannabee wannabee
WIL84911's Avatar
my 17 x 8.5 and 17 x 7.5s don't rub (lowered to euro specs).
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 08-12-2008, 09:41 PM
Do you have any neg camber dialed in to the rear?
If you are at zero rear camber and dial in 2.5 negative it should bring the top in about 1/2 inch if I have my numbers right. I think if you get some one that knows what they are doing they can slot the spring plate and get about -3 deg.
This is great for cornering bit not the best for a cruiser.
There is a small chance that if you put hard bushings at the spring plate and inner rear control arm it may keep the wheel from tilting a small amount in a corner which may help some.
Or you have to raise it, stiffen it, flair it, and or go to a more narrow tire.
Old 08-12-2008, 10:05 PM
2.2 targa 1971
put al cm of rubber bushing in the koni's
that's what i did
never had the problem again, and it doesnt feel hard by anny heavy bump in the road.
Old 08-13-2008, 12:16 AM
245 45 ZR 16
As has been suggested, a more aggressive alignment w/ as much (-) camber as you can get, stiffen up the bushes. I have seen bent trailing arms that caused that sort of issue too.
The lips can be shaved and in extreme cases ooched out a little
When the flares were welded on they may have decreased the room over oem a little
Bill Verburg
Old 08-13-2008, 05:27 AM
JMatta's Avatar
Your car looks beautiful! I have the same setup on my '73 with no issues and the car is tracked quite a bit. I run around neg 2.5* rear camber and am quite stiff with coilovers. As you can see from the pic, my car also sits quite low. Good luck getting it sorted out; it shouldn't be too tough a project.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 08-13-2008, 05:29 AM
.......When the flares were welded on they may have decreased the room over oem a little
I think so too. Measure the distance from the inner wheel well to the lip on both sides to confirm.
Sherwood
Old 08-13-2008, 08:25 AM
