abit off center
PCA DE Seatbelt 5 pt?
Having problems getting an answer to this question from PCA, I am putting in a 5pt belt but need to know can my shoulder belts go back in a V shape to one attachment point in the firewall or do I need two attachment points for the shoulder belts?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I don't know what PCA requires but I would use two mounting points and the firewall isn't strong enough to anchor belts unless you reinforce it considerably. I'd figure a load of at leat 1,500-2,000 lbs. at each anchor point. You also want to cross the belts. Schroth has some good installation recommendations on their web site.
JR Last edited by javadog; 08-14-2008 at 08:52 AM.. |
Platinum Member
What other equipment do you have in the car? Roll cage? Seats?
Follow belt manufacturer directions, or racing rules if you plan on racing. Good info here: http://www.schrothracing.com/main/Documents |
Insert Tag Line HERE.....
Some regions are different, but if they say 5 point specifically, then it has to attach at 5 points. Two sepereate shoulder, two hips, and one anti sub.
abit off center
Well, PCA just got back to me and you cannot use a Y style shoulder with one attachment point, Looks like the stock seat and belts are going back in then.
Schleprock
Craig,
I have a Sabelt 5/6point H-harness that you can use if you'd like. It's a cam-lock system that has two sub-belts of your choice- 5point or 6point. All you'd need is a harness bar (heck, you should make one!) or some eyebolts in the rear seat belt locations to hook these harnesses up. I had two of these harness systems for both driver and passenger. I sent one to Crow for "rewebbing" since the belts' certification dating were expired. I probably should have saved myself the $100 to re-web since nobody ever checks my harnesses, not to mention the requirement of re-webbing is a load of horseshiat to begin with!!! Let me know if you want it.
Kevin L '86 Carrera "Larry" |
abit off center
Kevin, I will take you up on that offer, I would like the belt with the single sub mount. I will fab up a bar, then go over the bar and attach to the rear seat belt mounts?
If you can send it that would be great, I will be in Chicago this weekend but not for car stuff
Remember PCA states if you have 5pt and race seat on the drivers you must have the same setup for the passenger. But you can run a stock 71 911 with 37 year old shoulder belts
Tony Proasi 1969S 1957 VW Pickup |
abit off center
But I hope thats ONLY if you are taking a passenger or instructor??
Certified Pre-Owned
Also, in my region at least, 5 and 6 points belts in DE cars must be replaced every 5 years from date of mfg, ala UV degredation. Don't buy used or old belts.
'84 Carrera Coupe |
In the Chicago region, you do not need a harness on the passenger side if solo; if you wish to have an instructor, however, you must have the safety harness setup for each seat, no exceptions (unless you wish to move down to the novice/green group).
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Diss Member
Racing organizations don't like the Y belts because if the seat is torn off of its mounts towards the back of the car the Y in the belts will break your neck.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Bill is Dead.
This is PCAs minimum standards: http://www.pca.org/members/library/PCA_DE_Guidelines.pdf
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
I'll get started on the bar this weekend while your in Chi-town I have all the demensions and the proper tube.
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
abit off center
Excellent! You have the car there too and KTL has the belts so I guess I'm in like flynn!! You all work while I drink
Pca
Guys,
The PCA rule changed this year and if running 5/6 point belts, you MUST have harness slots in seats. This prevents belts from separating and slipping off the outsides of your shoulders during impact. Also; There is a very good article on "The Science of Seat Belts" in the current (September) issue of Excellence Magazine. I will quote from this article: A properly-designed rollbar system will position the crossbar just below the drivers shoulders to ensure the proper shoulder-harness angle from the driver to the anchor points. As a basic rule of thumb, the shoulder harness should travel at no more than a ten-degree angle downward and no more than a 30-degree angle upward angle from the crossbar to the driver's shoulders.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
The seats do have slots and I also have the two guides on the bar for the shoulder harness to go threw
Schleprock
This rule is loosely enforced in my experience. When I ran my first event in 2004, the instructor (who was/is a Board member) had for me as a passenger in his car a crappy stock seat with stock belts. Meanwhile he's sitting in a nice new Sparco Evo with 6 pt. belts. Not easy to enforce the rules when the region Admin. are not following them themselves......... Craig, Harness is dropped off at FedEx Kinko's this morning. You should see it Monday.
