KatoKato's Avatar
Turn signal causing parking lights to go on...
After today's drive I turn the car off and get out and the parking lights are on.
Look inside light switch is in the off position
I've noticed this before and somehow it has magically worked itself out after going for a drive.
After abit of tinkering I found that when the car is not running(key not in ignition) that if I have the left or right blinker engaged the parking lights go on. When the car is running all light functions appear normal.
Anyone ever experience this?
Thanks in advance,
Kato
Old 10-21-2007, 05:43 PM
HarryD's Avatar
Hi,
Are only the lights on the side that the turn signal has activated on or ALL of them? If it is only the ones for the way you are signalling, this is not a defect but a feature to help illuminate your car if it is pulled to the side of the road. Clever them Germans.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-21-2007, 05:54 PM
avi8torny's Avatar
Send a message via AIM to avi8torny
Originally Posted by HarryD View Post
Hi,
If indeed it this clever German trick, you can defeat it simply. Underneath the dash near the steering column is a small rectangular plastic electrical plug. Simply unplug the connection it covers and this feature will be Kaput.
12' GT3
18’ 991S
Old 10-21-2007, 06:05 PM
Bird. It's the word...
Fishcop's Avatar
It is the curb lights and is a correct feature. If you don't want them on, don't leave the indicator/blinker stalk in the left or right position
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-21-2007, 06:26 PM
Noel's Avatar
THis is normal. I found this out by accident about three years ago and thought I had a ground problem.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 10-22-2007, 11:22 AM
KatoKato's Avatar
Thanks ... I thought that it may be a 'standard' feature and not a malfunction.
Don't remember reading about it in the manual.
Cheers,
Kato
Old 10-24-2007, 03:19 PM
FinallyGotOne's Avatar
yeah mine does this too, I thought it was a problem so to double check I pulled out every light and made sure right bulb ewas in, after a hour and a half of scratching my head, i checke d and the blinker was switched down. flipped it up and it was fine. Crazy.
Old 10-24-2007, 03:58 PM
They all do that. In fact for a number of years, almost all German cars had that feature. Had a VW squareback that did.
Old 10-24-2007, 04:01 PM
2002 996 C4S
jcsjcs's Avatar
Same deal with my former 87 944. This is a feature. When I was in Portugal a few years back I started to understand - they have some VERY narrow roads in Europe especially in the small towns- so this feature is useful when you park your car on the side of the road.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 10-24-2007, 04:07 PM
KatoKato's Avatar
I took a look under there and cannot find (am not sure) the plug you describe.
Do you have any pix of the area?
Old 08-15-2008, 11:07 AM
KatoKato's Avatar
Bump ... anyone?
Old 08-16-2008, 04:31 AM
