konahic
Send a message via Skype™ to konahic
SC Tachs
I am currently upgrading my '73T from the stock 2.4 with a 3.0 out of an '83 SC. It is my understanding that I will need to change the tach as well. My question is...does it have to come out of an'83 due to the CIS with lamda or will one out of an '80 work. Many thanks in advance for all of the advice & help. Kurt
Old 09-21-2008, 03:17 PM
Wer bremst verliert
JohnJL's Avatar
I'm 50% sure the original will actually work. I'm not sure the lambda box actually does anything to the tach signal, other than monitor it for its own purposes. Lots of people kluge things together with their SC tachs, using combinations of coils, MSD boxes, etc. I would just try it first.
Are you transplanting the entire 3.0 CIS, lambda box, etc? I started down the same road you are on but went with Webers and MSD and am happy I did.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-21-2008, 03:32 PM
konahic
SC Tachs
Thanx for the thoughts on the tach. I am planning on running the CIS at this time & was planning on adding a MSD. I have lots to do still & I can always swap out the tach last.
Old 09-22-2008, 07:47 AM
Send a message via AIM to fintstone
Kept the original tach (made in '73) from my '74 when I had an '83 3.0 installed.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-22-2008, 08:56 PM
