Throw it on the ground!
Planning on selling my 3.2 engine - what's it worth?
Just bought a low mileage 3.2 engine from another Pelican to replace my stock 3.2 motor with 171,000 miles rather than go down the rebuild slipery slope. Besides, it's my driver and down time is an issue. Need help on determining its value. My thought is to post it on the classifieds here while its still in the car and running in case any locals or near bys want to see/drive it. I'm probably looking at 30-60 days before I'll be ready to do the swap and sell the engine at the earliest.
Here are the details on the engine: 171,000 miles (have all records since 57,000 miles) I've owned car for 2 years bought from neighbor who owned for 10 yrs No engine work Car has never been tracked Worn valve guides/ oil consumption = 1/2 qt per tank of gas Pics from last plug change attached (oil worst on 2, 3 & 6) Smokes on start-up Has just started smoking some at idle (only notice when engine it hot) Has a little chain rattle at 2,000 -2500 rpm only when hot No chain rattle when cold and no rattle at higher rpms ever No compression or leak down test data - valve guide wear is evident Oil pressure per guage is good at 4 bars Engine runs great & pulls strong - just consumes oil No leaks (just replaced driver side oil tensioner line and now no leaks) I'll put the car up on jack stands this weekend an post some pics of the underside. Thanks! Engine: ![]() Old Plugs ![]() Donor:
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 08-20-2008 at 03:50 AM.. |
My thoughts:
I would first wait for the newly purchased engine to prove its actual condition, Then I would seriously consider taking the time to rebuild the engine that belongs to the car; you have all the time to do it right .... and swap and sell the alien again. Your engine is "tired" and needs a rebuild; I would count on a value of USD 3-4.500. If you do want to sell indeed sell it with the engine still in the car so potential buyers can drive it.
Better a good one for a lot of bucks, than a bad one for little Last edited by lindemans; 08-18-2008 at 04:26 PM.. |
+1 to lindemans' idea.
Practical or not, the satisfaction of learning to rebuild your own engine/gearbox would have to be right up there with any 911 project. Hope it all works out.
1987 Carrera 3.2 |
Hi Mark, if you decide to sell the engine, would it be the engine be sold as is in a complete condition? Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Hi Mark,
That old engine is absolutely worthless. In fact, it is a health and safety risk. Send it to me and I'll get rid of it for you at no charge...
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
Yes, that would be the idea. The engine I've purchased is a complete drop in replacement (ex DME and coil) and that is how I'd sell this one.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Friend of Warren
I'll give you my opinion. That engine at the very least needs a top end rebuild and probably close to needing a complete rebuild. It only has a core value, which in this market is around $2000.00
Kurt V No more Porsches, but a revolving number of motorcycles. |
I was thinking as a good running core it might fetch a higher value than "core value" I guess I'll find out soon enough but appreciate the opinions!
Yeah, even cores seem to get more than that. Sorry, Kurt.
If you were closer, I'd have a look at the old motor. Sure looks nice! |
Mark, PM sent. Tony.
Ya ... cores are going for more than $2k.
3.0s seem to be in the 2K - 3K range. As a 3.2, I would put it around $2500. If you parted out the engine you could get more than $2500 ... lots of people want cases, cranks, fuel systems, exhaust, heads, etc. Just look at the classifieds on this board.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
At least swap that fan
![]() I think this engine getting core value (for a complete engine) is accurate. Although running, it is not in great shape and a core engine doesn't necessarily mean it is completely non-operational. 99% of buyers will see this as a motor to be rebuilt. In the end, I don't know what a complete motor is worth core or not. |
(actually she's supportive on everything non-Porsche related)
