MFI Injector lines
I'm gathering information to document how to rebuild (make from scratch) replacement MFI injector lines.
Material = Double wall steel bundyweld tubing (can any body confirm internal and external diameters and materials ?) Flare form Warren Hall Jnr (Early S Man) posted some time back that the lines used a DIN flare I'm assuming that this is similar to the DIN 74234 bubble flare form 'F" (see below) but haven't determined if it was the "F" or "F 180°" form - any suggestions ?? Nut and recesses would be to DIN 74233 parts 1 Nuts, and 3 Bores) ![]() In both F forms - the end is finished at an angle of 115°, which provides a small amount of "crush" as it tightens against the 60° cone of the injector inlet - effecting the seal. The difference between the F and 180° F is at the back of the flare - the 180° form has a right angle step in the tubing, versus the gentle "bubble" form of the standard F form. Hazet, Stahlwille (#165) , Gedore etc all make flare tools to deliver these flare forms. Any info or pics (esp closeups with caplier dimensions of the standard flare form)would be greatly appreciated. Thanks John Last edited by jcge; 08-19-2008 at 07:00 PM.. |
MFI fuel Lines
I checked my lines and it is the "F" doppel-boerdel
The inside diameter is 2mm Outside diameter is 6mm the finished boerdel diameter is 8.5mm hope this will help Fritz |
Thanks Fritz - appreciate your rapid response
John |
Here's a link to TI Group's automotive division (the owners of "bundyweld tubing")
Bundyweld Tubing Based on their product lineup, I'm assuming the wall thickness for the tube is 0.028" = 0.71mm Can anybody confirm this spec ? John |
tubing wall thikness
0.028 inch = 0.071 12 centimeter
you are correct |
