-   -   How To: Relocate Console Switch to Dashboard (http://forums.pelicanparts.com/porsche-911-technical-forum/426175-how-relocate-console-switch-dashboard.html)
ShakinJoe 08-20-2008 03:49 PM
Many of you have been watching my 87 Carrera "Jenny Craig" thread on weight loss.
http://forums.pelicanparts.com/porsche-911-technical-forum/423361-438-lbs-gone-5-days-my-build-story.html
I wanted to post separately some items that might be useful, where you did not have to dig thru my boring thread to find it. One of them is the switch relocate that I could not find a ton of info on, so I decided to document it for the forum as I have received much more from this forum than I have contributed.
In short, I have removed things from my 911 that I do not use or...really need in effort to remove weight for HP and handling reasons. I will still drive it on the street sparingly, so it has to have the necessary switches and items needed for obvious reasons. Since I deep sixed my console; I need a place to put may Hazard Switch as I definately want to keep it. This thread can be used for any of the switches that might be relocated to the dash...but the Hazard and R Def are the hardest.
Enjoy............................................. ...............
http://forums.pelicanparts.com/uploa...1219272111.jpg
http://forums.pelicanparts.com/uploa...1219272133.jpg
http://forums.pelicanparts.com/uploa...1219272155.jpg
http://forums.pelicanparts.com/uploa...1219272178.jpg
http://forums.pelicanparts.com/uploa...1219272193.jpg
http://forums.pelicanparts.com/uploa...1219272212.jpg
ShakinJoe 08-20-2008 03:53 PM
PART TWO of SWITCH RELOCATE
Here is the remainder as there were too many pics!!!
http://forums.pelicanparts.com/uploa...1219272630.jpg
http://forums.pelicanparts.com/uploa...1219272647.jpg
http://forums.pelicanparts.com/uploa...1219272665.jpg
http://forums.pelicanparts.com/uploa...1219272687.jpg
http://forums.pelicanparts.com/uploa...1219272704.jpg
http://forums.pelicanparts.com/uploa...1219272719.jpg
http://forums.pelicanparts.com/uploa...1219272732.jpg
http://forums.pelicanparts.com/uploa...1219272748.jpg
http://forums.pelicanparts.com/uploa...1219272768.jpg
NOW....you can do it too!!!
x98boardwell 08-20-2008 04:21 PM
Shakin Joe
Great Job, Very clean and well detailed post. Thanks
rfloz 08-20-2008 04:46 PM
Nicely done DIY. These old eyes especially appreciate the large print version.:)
Question - If this is really going to be a lightweight car, why do I still see a cigarette lighter, ashtray and glove box cover? Ounces, man, ounces.
No, I'm not kidding. The first two are gone from mine, but getting the glove box cover out is making me nuts. You need to remove the passenger side lower dash pad and there are two, maybe three, screws you have to get from the backside of the dash. I can barely feel two of them and can't even figure out what size nut-driver I need. Feel free to do an illustrated DIY on that one anytime.
ShakinJoe 08-20-2008 05:03 PM
rfloz,
Thanks for the reply. My build thread rambles about what lightweight means to me. It will still be used for street, but I just do not use the heat, AC, and a lot of other crap, so I took it out and weighed each and every piece! See my thread. http://forums.pelicanparts.com/showthread.php?t=423361
But I am not done yet inside. I will take out the ashtray, and a few more things, but I cannot see getting more than 20 lbs out of the car from the inside stuff. My biggest weight now are windows...and I am not prepared to do that yet. Notice the word yet.
On the lower dash removal, there are three nuts (all 8mm) and one screw. It took me one hour to get it out the first time....now I can do it in 5 minutes. If there is enough response to this, I will do a thread on it. I did cheat a little and used a video inspection camera made by Testo to find the nuts.....absolutley incredible!
http://www.testo.us/online/abaxx-?$part=PORTAL.USA.Applications&$event=show-from-content&externalid=opencms:/Products/MeasurementParameters/ambientairquality/Messgeraete/318VPRO_JUST_USA/USEnglisch.product
Thanks for the positive comments.
Mysterytrain 08-20-2008 05:57 PM
Nice work Joe but I would have ripped that blank radio plate a new 'hole'..well a couple and mounted the switches there. You can also convert the air pump connections to clamps and use a direct connection to the battery when you need to pump, then you can remove the lighter. Of course, because you live in Florida you can remove the turn signals and the turn signal switch...sorry I couldn't resist. ;)
ShakinJoe 08-20-2008 06:26 PM
Hey MTrain
I knew someone would go there...but it is so well deserved!! Too many driving styles on one road = recipe for lots of disasters. I left the blank alone as most users will still have their radio...and well, it was the easy way out and we cannot have that!!! Thanks for the reply!!
Mysterytrain 08-20-2008 07:17 PM
Everytime I visit a thought enters my mind...all the 16 year old drivers on drugs, all the seniors medicated and no one uses the turn signals...totally amazing driving situation. So I prefer a rental car. Your car looks great..be careful!
ShakinJoe 08-20-2008 07:31 PM
You're forgettin' all the drivers from Jersey!!!!
dshepp806 08-21-2008 08:11 AM
Good Work Shakin' Joe.
Best,
Doyle
rfloz 08-22-2008 09:31 AM
Joe-
Thanks for the info. Using an old-tech long handled mirror, I found the 8 mm nuts, but not the screw.
Do you remember where that is located?
BTY, just so you know it's well worth it;), the ashtray and cigarette lighter together weigh 10 oz. and that (usually) non-functional clock is 6 oz. Hey, that's a whole pound!
ShakinJoe 08-22-2008 08:37 PM
Originally Posted by rfloz (Post 4134251)
Joe-
The screw is removed from the end panel (under vent) from outside. It should be visible. The mirror is good....this camera was awesome!
Clock is sold...and gone. An Atlanta Pelican convinced me that he needed it more than I did.....and he was right dawg gone it!! Ashtray to be removed upon return of car. I just want to make sure my neon under dash street light system is well hidden!! kidding of course
rfloz 08-24-2008 08:44 AM
Thanks.
Keep the neon; it's eVaR so kEwL!http://forums.pelicanparts.com/support/smileys/puke.gifhttp://forums.pelicanparts.com/support/smileys/puke.gifhttp://forums.pelicanparts.com/support/smileys/puke.gif
jsfried18 08-05-2021 10:46 AM
If you use the step bit right off the bat would the switch still stay in if you went all the way down to the 1 1/8” to get through the metal plate behind or do you need a hole saw for that part?
Geronimo '74 08-06-2021 01:24 AM
good advice, after thirteen years...
Gretz 01-16-2023 10:51 AM
This is pretty handy, thanks. I removed the console long ago and will be relocating the AC and fan switches to the dash. Good to know it’s about as straightforward as I envisioned.
Mr. Merk 06-18-2023 08:47 AM
Were you able to stretch the wiring up there or did you have to extend it?
Snitzler 06-18-2023 10:23 AM
I thought I had some charging problems so I got a USB charger with a voltage read out. I went over my grounds and charging problem went away. I was relocating the console switches so I might as well get a gauge for the volts as it looks better. This what I did.
http://forums.pelicanparts.com/uploa...1687108797.JPG
Gretz 06-20-2023 10:09 AM
I ended up relocating my AC control switches to the dash, and it was a much bigger project than expected. I had to add a section of wiring harness and also fit the square AC thermostat switch into the round hole on the backside of the dash. But the end result was worth it. Now I can re-carpet the car and have a clean floor around my Wevo shifter.
http://forums.pelicanparts.com/uploa...1687280845.jpg
fallingat120mph 02-23-2024 07:49 AM
Started the process today - waiting on the knock out bit (had to be ordered).
It was...very...nerve wracking to drill out the initial 1 inch hole. I did the 2 step approach as I felt comfortable with that. Will expand the hole slowly with the new bit.
http://forums.pelicanparts.com/uploa...1708703252.jpg
Redoing the interior and center console delete so this came in handy. Will post a finished photo this weekend.
Erik
Michael. 02-26-2024 10:34 AM
This is fantastic. My car has no center console and have been wanted to rearrange where some of the switches are located. I'd like to have the fog switch next to the headlight switch. Then put the hazards and rear defrost up next to the other HVAC controls
fallingat120mph 02-26-2024 11:10 AM
From the front:
http://forums.pelicanparts.com/uploa...1708974259.jpg
From the back of the dash (I did add bonding agent around the cut hole contact with the flasher back):
Just research the heck out of your layout and make sure to check for clearance behind where you are thinking about drilling.
Also make sure the wires/harness reach.
I am gutting my HVAC behind the dash (from the trunk) and it made everything clear once that was all removed.
I really wanted to put the hazards switch to the right of my steering column but the room behind it was tight and would have interfered (in my case) with the sliders/cables of the HVAC controls. (86 coupe)
Also.......check your switches and make sure they marry up flat to the new hole/dash. The flasher button on my 86 had a tab that wouldn't let me push it in flush at first. Had to grind it down a pinch. It's right behind the lip and must have lined up on the floor center console...I don't have a photo, sorry. Just inspect your light switch and make sure it will go flush...
The two bits he recommended work perfectly. It was a good tight fit after I finally got things installed.
Really recommend taking everything out of the trunk first, checking clearance where you think you want to drill, and verify the wires/harness can reach new locations. I actually trimmed about 2 ft off the hazards and removed the connection for the rear defroster. I will never use and capped off the wiring.
I am no expert but just wanted to give you my amateur process. VERY amateur :)
Best of luck.
Erik
Michael. 02-28-2024 10:48 AM
All very very helpful. We'll see what I can make of it on MY 86 coupe
