-   -   Do I need to rebuild my front calipers? 1980 sc (http://forums.pelicanparts.com/porsche-911-technical-forum/426397-do-i-need-rebuild-my-front-calipers-1980-sc.html)
Porsche_monkey 08-23-2008 03:56 PM
I'm looking for suggestions on how to easily instal the boot. The standard answer of 'use a mustard jar lid' does not work with the jars in Canada.
KTL 08-24-2008 10:48 AM
I used to rebuild my A & M sized Porsche calipers once a year due to heat damage from track use. Seems every year one of the guys in our local group says they find a puddle under the front of the car at the end of the year. Heat gets the best of these front calipers after about 6-7 track days and the seals begin leaking.
Brake cooling or regular inspection is a must with these cars if you track them hard!
richde 08-24-2008 01:40 PM
Originally Posted by Flieger (Post 4135011)
In response to therotman,
I bought newly restored S calipers from Eric Shea. They had been re-anodized, had new stainless steel pistons installed, new stainless steel crossover lines, etc.
I then sold my old calipers back to him as cores. The 2 sets of calipers were the same specification of Ate aluminum S caliper for the 1971 model year.
His price was great and the work was excellent. S calipers have a higher market value than A or M calipers. The brakes work smoothly and forcefully. They can be modulated better and the pedal is positioned better for throttle blips on downshifts.
I will PM you with the price I paid.
Most calipers don't have that finish to begin with, so spending however much he charges is a bit of a waste. I got rebuilt front calipers from somewhere I'd have to look up, but it was way less than $70 each without the core charge. I rebuilt the rears myself and I thought the slightly higher price for the rebuilt ones were worth it versus the extra labor.
Flieger 08-24-2008 03:11 PM
S calipers?
Britwrench 08-24-2008 05:27 PM
Don't forget to replace the flexible hoses and think about replacing the 28 year old master cylinder...
